anishtain4 Posted December 12, 2011 Share Posted December 12, 2011 anyone has a lips that can locate center of gravity of lines of an open polyline? Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted December 12, 2011 Share Posted December 12, 2011 If your pline doesn't have arcs, this should work (defun c:cgpline (/ dst lst mdp mdx mdy ss x y en pt) (if (setq ss (ssget ":E:S:L" '((0 . "LWPOLYLINE")))) (progn (setq lst (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) (setq en (entget (ssname ss 0))) ) ) dst (mapcar 'distance lst (cdr lst)) mdp (mapcar '(lambda (x y) (mapcar '(lambda (a b) (* 0.5 (+ a b))) x y) ) lst (cdr lst) ) mdx (mapcar 'car mdp) mdy (mapcar 'cadr mdp) x (/ (apply '+ (mapcar '* mdx dst)) (apply '+ dst)) y (/ (apply '+ (mapcar '* mdy dst)) (apply '+ dst)) pt (trans (list x y (cond ((cdr (assoc 38 en))) (0.0) ) ) (trans '(0. 0. 1.) (cdr (assoc 210 en)) 0 T) 0 ) ) (entmake (list '(0 . "POINT") (cons 10 pt))) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 12, 2011 Share Posted December 12, 2011 http://www.theswamp.org/index.php?topic=18725.0 Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 12, 2011 Share Posted December 12, 2011 @Stefan . I think your routine not give the correct center point a Polyline . My version .... with window selection set which means as many as you want with one shut . (defun c:TesT (/ pl i sn e lst pts n i x y) ;;; Tharwat 12. Dec. 2011 ;; (if (setq pl (ssget '((0 . "*POLYLINE")))) (repeat (setq i (sslength pl)) (setq sn (ssname pl (setq i (1- i)))) (setq e (entget sn)) (setq lst (vl-remove-if-not (function (lambda (x) (if (eq (car x) 10) (setq pts (cons (list (cadr x) (caddr x)) pts)) ) ) ) e ) ) (setq i 0 x 0 y 0 ) (repeat (setq n (length pts)) (setq x (+ (car (nth i pts)) x)) (setq y (+ (cadr (nth i pts)) y)) (setq i (1+ i)) ) (entmake (list '(0 . "POINT") (cons 10 (list (/ x (length pts)) (/ y (length pts)))))) ) (princ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 12, 2011 Share Posted December 12, 2011 The cheat's way: (defun c:test ( / c o r s ) (vl-load-com) (if (setq s (ssget "_+.:E:S:L" '((0 . "*POLYLINE")))) (progn (setq o (vlax-ename->vla-object (ssname s 0)) s (vla-objectidtoobject (vla-get-activedocument (vlax-get-acad-object)) (vla-get-ownerid o)) c (vla-get-closed o) ) (vla-put-closed o :vlax-true) (setq r (car (vlax-invoke s 'addregion (list o)))) (vlax-invoke s 'addpoint (trans (vlax-get r 'centroid) 1 0)) (vla-delete r) (vla-put-closed o c) ) ) (princ) ) @Tharwat, I don't see the point of: (setq lst (vl-remove-if-not (function (lambda (x) (if (eq (car x) 10) (setq pts (cons (list (cadr x) (caddr x)) pts)) ) ) ) e ) ) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 12, 2011 Share Posted December 12, 2011 @Tharwat, I don't see the point of: (setq lst (vl-remove-if-not (function (lambda (x) (if (eq (car x) 10) (setq pts (cons (list (cadr x) (caddr x)) pts)) ) ) ) e ) ) I am sure that you know each piece of the code , and if you indicate to the two names of variables , actually I just wanted to get the coordinates without the first 10 of each one . By the way , have you seen this request Here ? Thanks Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 12, 2011 Share Posted December 12, 2011 I am sure that you know each piece of the code , and if you indicate to the two names of variables , actually I just wanted to get the coordinates without the first 10 of each one . I was indicating that the use of the vl-remove-if-not function is redundant since you are not using the list returned (variable 'lst'). Consider instead the following: (foreach pair (entget <entity>) (if (= 10 (car pair)) (setq pts (cons (cdr pair) pts)) ) ) Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted December 12, 2011 Share Posted December 12, 2011 (edited) @Stefan . I think your routine not give the correct center point a Polyline . I think OP wants the CG of the contour, like a very very thin wire... anyone has a lips that can locate center of gravity of lines of an open polyline? I could be wrong, then indeed my point is calculated wrong. In the link given by Lee, Evgeniy gave three methods for calculating the center of gravity: 1) for an area 2) for an outline 3) for the masses concentrated in nodes Mine calculates center of gravity as in the second. On the other hand, I tried your lisp and Lee's ... The results are different ... Edit: Tharwat, your routine is calculating the media of vertices position, not a gravity center. Edited December 12, 2011 by Stefan BMR Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 12, 2011 Share Posted December 12, 2011 I was indicating that the use of the vl-remove-if-not function is redundant since you are not using the list returned (variable 'lst'). Consider instead the following: (foreach pair (entget <entity>) (if (= 10 (car pair)) (setq pts (cons (cdr pair) pts)) ) ) That's right , and besides that we can use mapcar function also for the same situation . (mapcar (function (lambda (x) (if (eq (car x) 10) (setq pts (cons (list (cadr x) (caddr x)) pts)) ) ) ) e ) Thank you Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 12, 2011 Share Posted December 12, 2011 My code above is returning the centroid, Tharwat is just averaging the points which I believe would only work on regular polygons and triangles. Here is another way to return the centroid for an LWPolyline Polygon: ([color=BLUE]defun[/color] c:test ( [color=BLUE]/[/color] e ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] e ([color=BLUE]ssget[/color] [color=MAROON]"_+.:E:S"[/color] '((0 . [color=MAROON]"LWPOLYLINE"[/color])))) ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"POINT"[/color]) ([color=BLUE]cons[/color] 10 (LM:PolyCentroid ([color=BLUE]ssname[/color] e 0))))) ) ([color=BLUE]princ[/color]) ) [color=GREEN];; Polygon Centroid - Lee Mac[/color] [color=GREEN];; Returns the centroid of an LWPolyline Polygon[/color] ([color=BLUE]defun[/color] LM:PolyCentroid ( e [color=BLUE]/[/color] l ) ([color=BLUE]foreach[/color] x ([color=BLUE]setq[/color] e ([color=BLUE]entget[/color] e)) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 10 ([color=BLUE]car[/color] x)) ([color=BLUE]setq[/color] l ([color=BLUE]cons[/color] ([color=BLUE]cdr[/color] x) l))) ) ( ([color=BLUE]lambda[/color] ( a ) ([color=BLUE]trans[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]/[/color] ([color=BLUE]apply[/color] '[color=BLUE]mapcar[/color] ([color=BLUE]cons[/color] '[color=BLUE]+[/color] ([color=BLUE]mapcar[/color] ([color=BLUE]function[/color] ([color=BLUE]lambda[/color] ( a b ) ( ([color=BLUE]lambda[/color] ( m ) ([color=BLUE]mapcar[/color] ([color=BLUE]function[/color] ([color=BLUE]lambda[/color] ( c d ) ([color=BLUE]*[/color] ([color=BLUE]+[/color] c d) m)) ) a b ) ) ([color=BLUE]-[/color] ([color=BLUE]*[/color] ([color=BLUE]car[/color] a) ([color=BLUE]cadr[/color] b)) ([color=BLUE]*[/color] ([color=BLUE]car[/color] b) ([color=BLUE]cadr[/color] a))) ) ) ) l ([color=BLUE]cons[/color] ([color=BLUE]last[/color] l) l) ) ) ) ([color=BLUE]list[/color] a a) ) ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 210 e)) 0 ) ) ([color=BLUE]*[/color] 3.0 ([color=BLUE]apply[/color] '[color=BLUE]+[/color] ([color=BLUE]mapcar[/color] ([color=BLUE]function[/color] ([color=BLUE]lambda[/color] ( a b ) ([color=BLUE]-[/color] ([color=BLUE]*[/color] ([color=BLUE]car[/color] a) ([color=BLUE]cadr[/color] b)) ([color=BLUE]*[/color] ([color=BLUE]car[/color] b) ([color=BLUE]cadr[/color] a))) ) ) l ([color=BLUE]cons[/color] ([color=BLUE]last[/color] l) l) ) ) ) ) ) The above return the same result as my previous code (which uses regions) and the same result as gile's code in the linked thread for LWPolyline Polygons (i.e. non-self-intersecting LWPolylines with straight-segments). Quote Link to comment Share on other sites More sharing options...
