Need help with this lisp
asos2000
Some times comes a file has all the project drawings.
All frames on one layout (as attached)
So I wrote this simple lisp
(defun c:Mltiplt ()
 (alert "make changes in next window \nthen click on Apply to Layout \nthen click on Canel")
 [color="red"](command "_plot")[/color]
 (while t
   (setq p1 (getpoint))
   (setq p2 (getpoint))
   (command "-plot" "y" "" "" "" "" "" "" "w"
     p1
     p2
I am facing 2 problems
- How to open Plotting window
This error message comes
Command: (command "_plot")
nil
- Could I change the layout in WHILE Loop?
Thanks for help
Hi,
To open the AutoCAD plot window add (initdia) directly before (command "_plot"). This allows you to override the command line by launching the plot dialog box
(initdia)
(command "_plot")
To control the loop I'd change the
 (while t
to
  (while
   (and
(initdia)
(command "_plot")
Working perfect
But when Plotting dialog box launched and select a window in plot area the Function cancelled
Command: MLTIPLT
Invalid window specification.
; error: Function cancelled
Specify first corner: *Cancel*
*Invalid*
 (while t
[/code]
Did not solve the problem
Thanks for your help
i never had to reset my initdia
And i use ".-plot", repeat and vla-getboundingbox for loop
(setq ss (ssget "x" (list '(0 . "INSERT")(cons 2 [color=blue][b]Blkname[/b][/color])(cons 410 (getvar 'CTAB)))))
(vla-getboundingbox
       (setq blockobject
         (vlax-ename->vla-object (ssname ss (setq i (1- i))))
       'lowerleft 'upperright
(command [color=blue][b]".-plot"[/b][/color] "Y" "" "pltDevice"   "ANSI B (11.00 x 17.00 Inches)"
   "Inches" "Landscape"
   "N" "Window" (trans (vlax-safearray->list lowerleft) 0 1)
   (trans (vlax-safearray->list  upperright) 0 1) "Fit" "Center" "Y" "pltStyles" "Y" "Y" "N" "N"
   "N" "N" "Y")
Hope this helps
Okay I see whats happening. At first I thought it could be something to do with the dialogFlag which you can add to the (initdia ) but its not the case.
When you launch the plot dialog box, and press the select window button, you actually proceed to the loop instead of picking the points as per the plot window. Adding a double pause as shown seems to work but you might want to test this
(defun c:Mltiplt ()
 (INITDIA)
 (command "_plot" pause pause )
 (while
   (AND
   (setq p1 (getpoint "\nBottom left"))
   (setq p2 (getpoint "\nUpper right"))
     p1
     p2
Oh.. now I see what the OP is trying to do. fire up the Plot Dialog to set the parameters on the first window selection. and use "-plot" afterwards.
My bad.
Clever guys. :thumbsup:
I am more like Pbe plot all titleblocks automatically or pick the ones you want or pick smaller title and do all, or just one could be all sorts of combo's ?
Maybe pick 1 title then use selection set rather than "X" change plot scale if required.
I just say plot all and done I use the title block insertion point and work out the plot "window" co-ords as I know the title block sheet size, I have 4 options A3 A1 tiff PDF.
Why not ignore default plot window all together and just ask questions with as default
  • 3 weeks later...
Yes if you make an outside loop that is your layout tabs then it will go to the next one and run again.
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for lay (vla-get-Layouts doc)
 (setq plotabs (cons (vla-get-name lay) plotabs))
(setq plottablist (acad_strlsort plotabs))
(setq len (length plottablist))
(setq x 0)
(repeat len
 (setq name (nth x plottablist))
 (princ name)
 (if (/= name "Model")
     (setvar "ctab" name)
your code
Thanks Bigal,
This is what I have but I get ; error: malformed list on input
;Based on PageSetups from Alan J. Thompson
(defun c:A1_All ()
(PlotReactorOFF)
 (if (findfile "T:/Drawing Tools/Templates/CCC2009.dwt")
     (command "_.psetupin" (findfile "T:/Drawing Tools/Templates/CCC2009.dwt") "A1")
     (while (wcmatch (getvar "cmdnames") "*PSETUPIN*")
       (command "_yes")
     ) ;_ while
     T
   ) ;_ progn
 ) ;_ if
(setq x 0)
(repeat len
 (princ name)
(command "-plot" "n" "" "A1" "" "n" "y" "n")
(command "_-purge" "a" "*" "N")
(setq CCC_Sheet "A1")
(command "updatefield" "all" "")
(command "regenall")
(command "_zoom" "e")
 (initdia)
 (command "._plot")
(PlotReactorON)
;(princ)
Can you help?
