how can i make a lisp that opens a drawing
MikeP
I want something like this. Obviously this does not work though and there is a lot im missing. but how can I make it work
(defun c:opend ( / dwg1 dwg2 dwg3)
(setq dwg1 (C:\Jobs\dwg1.dwg))
(setq dwg2 (C:\Jobs\dwg2.dwg))
(setq dwg3 (C:\Jobs\dwg3.dwg))
(prompt "\nwhat drawing would you like to open?")
(command "open" dwg2)
  • Replies 21
  • MikeP
    9
  • BlackBox
    8
  • MSasu
    3
  • Lee Mac
    2
Posted Images
Since you are using an AutoCAD version that still supports VBA:
(setq dwg1 "\"C:\\Jobs\\dwg1.dwg\"")
(command "_VBASTMT" (strcat "AcadApplication.Documents.Open " dwg1))
But, please keep in mind that each drawing has his own namespace.
As general rule, when want to store a path on a variable:
[s](setq dwg1 (C:\Jobs\dwg1.dwg))[/s]
(setq dwg1 [color=red]"[/color]C:\[color=red]\[/color]Jobs\[color=red]\[/color]dwg1.dwg[color=red]"[/color])
am i getting closer?
(defun c:opend ( / dwg1 )
(setq dwg1 "C:\\Jobs\\dwg1.dwg"))
((setq dwg (getkword "\nwhat drawing would you like to open? <>"))
(command "_VBASTMT" (strcat "AcadApplication.Documents.Open dwg))
Or, using VisualLISP extension:
(vl-load-com)
(vla-open (vla-get-documents (vla-get-application (vlax-get-acad-object))) "C:\\d1.dwg")
Something like this? Although I'm really not sure what are you looking to achieve by that...
(defun c:opend ( / dwgName dwgPath )
  (setq dwgPath "C:\\Jobs\\")
  (initget 1 "DWG1 DWG2 DWG3")
  (setq dwgName (getkword "\nWhat drawing would you like to open? (Dwg1/Dwg2/Dwg3):"))
  (setq dwgName (strcat dwgPath "\"" dwgName ".dwg" "\""))
  (command "_VBASTMT" (strcat "AcadApplication.Documents.Open " dwgName))
You must be more careful with usage of parenthesis!
i ave a few drawings I like a access quickly and i figured a list that i can type a nickname would be easiest, rather than opening it using the open box
FWIW - I use this for many commonly opened reference drawings. Can also be used in a toolbar/ribbon button macro. :thumbsup:
(defun _OpenDwg  (dwg readOnly / f oDwg)
 [color=green];; RenderMan, CADTutor.net
 ;; Example: (_OpenDwg "[/color][color=red]FilePath[/color][color=green]\\[/color][color=blue]FileName[/color][color=green].dwg" T)[/color]
 (vl-load-com)
 (if (and (setq f (findfile dwg)) (/= 1 (getvar 'sdi)))
   (vla-activate
     (vla-open (vla-get-documents (vlax-get-acad-object))
               f
               (cond ((= T readOnly) :vlax-true)
                     ((:vlax-false)))))
   (cond (f (prompt "\n** Command not available in SDI mode ** "))
         ((prompt (strcat "\n** \""
                          (strcase (vl-filename-base dwg))
                          "\" cannot be found ** ")))))
 (princ))
Lee - Out of curiosity, how has that code worked with multiple versions (and the whole which version is default scenario)...?
I haven't test LM:Open for myself yet, but we've got Land Desktop 2009, Raster Design 2009, Civil 3D 2011, Map 3D 2011, Raster Design 2011, Civil 3D 2012, AMEP 2012, Raster Design 2012 all installed. I'm wondering if the Shell.Application InterfaceObject knows to open the drawing argument with the Active version calling the function or not.
Cheers! :beer:
The behaviour of the Open method of the Shell.Application object I believe is the same as double-clicking the file in Explorer to open it - i.e. it will open with the default application associated with the filetype.
 (vl-load-com)
   (vla-activate
               f
                     ((:vlax-false)))))
 (princ))
how do i modify this to open the specific dwg i want? I dont see where to enter the file path
[ATTACH=CONFIG]34975[/ATTACH]
[ATTACH=CONFIG]34974[/ATTACH]
Thanks dick..... only reason I'm confused is because the ;; tells the program to ignore that line...... Obviously im not the best at lisp
So I did this.
(defun ODwg (dwg readOnly / f oDwg)
;; Example: (_OpenDwg "S:\Blocks\SBUX Shop Drawings\Countertops\Saved\Temporary Ctop Library\Master Ctop Drawing.dwg" T)
(vl-load-com)
(vla-activate
f
((:vlax-false)))))
(princ))
I enter "_OPENDWG" at the command line
And it tells me unknown command
Perhaps I was unclear... _OpenDwg is a sub-function that requires two arguments:
dwg - a file (path and/or name) as string
readOnly - T or nil
In order to call this sub-function from the command line, you must encapsulate the call with parens, like so:
(_OpenDwg "S:\\Blocks\\SBUX Shop Drawings\\Countertops\\Saved\\Temporary Ctop Library\\Master Ctop Drawing.dwg" T)
** Note the double back-slashes "\\"
The comments (the lines prefixed by ";;" are meant to be useful to you, the user, alone, and are not passed onto the command line, or the VLIDE.
A sample macro, for your CUI command could be:
^C^C^P(_OpenDwg "S:\\Blocks\\SBUX Shop Drawings\\Countertops\\Saved\\Temporary Ctop Library\\Master Ctop Drawing.dwg" T)^P
HTH
FWIW -
The purpose of a sub-function, generally speaking, is to isolate a specific task, or series of (in this case to open a drawing), in order to be used multiple times, sometimes in a row, or sometimes simply to allow the user (in this case you) to feed the sub-function a different parameter (aka argument)... in this instance, the sub-function can perform the same task on any valid drawing file that you supply to the sub-function as an argument.
Is this starting to make (more?) sense now...? :unsure:
FWIW -
Honestly, just barely. *If I enter
into the command line it opens the dwg. *the LISP file does not want to work though
The part that I am confused about it, What command do I enter to open this file path? Should typing"_opendwg" open the dwg?
Okay, let's back up for a moment.
If you want to create a LISP Command that can be invoked at the command line by typing in the command name, this is the syntax:
;; Define the function
(defun [color=red][b]c:[/b][/color][color=blue]HelloWorld[/color] ()
 (princ "\nHello World! ")
Sample command line output:
Command: [color=blue]HelloWorld[/color]
Hello World!
Command:
Where the c: prefix (optional) to the Defun function's Symbol argument tells AutoCAD to allow this function to be called from the command line, and HelloWorld is the command that one would type at the command line. Together these are the function's Symbol. This syntax does not accept arguments.
By not including the c: prefix, the Defun function's Symbol argument is treated as a sub-function... Something that can accept arguments (optional), and can only be invoked by encapsulating the call within parenthesis (aka parens), like so:
;; Define the sub-function
(defun [color=blue]SayIt [/color]( [color=magenta]string [/color])
 (prompt [color=magenta]string[/color])
Command:  ([color=blue]SayIt [color=magenta]"\nHello World!"[/color][/color])
Hello World!
Command:
Note that any Defun can be invoke when encapsulated in parens, like so:
Command:  ([color=red][b]c:[/b][/color][color=blue]HelloWorld[/color])
Hello World!
Command:
Now, the _OpenDwg sub-function... The LISP *is* working, and you've successfully called the sub-function with the required arguments.
Does any of this help, or are you still lost in a world of [developer] malarkey? :unsure:
