How do I list it can be with a print or alert,
all polylines that have not been closed within my DWG?
Try this and it would highlight the open polylines .
(defun c:test (/ ss x sn lst l)
 (vl-load-com)
 (if (setq
       ss (ssget "_x"
                 (list '(0 . "*POLYLINE") (cons 410 (getvar 'ctab)))
     (setq sn (ssname ss (setq x (1- x))))
     (if (not (vlax-curve-isclosed sn))
       (setq lst (cons sn lst))
 (setq l (ssadd))
 (sssetfirst nil (foreach x lst (ssadd x l)))
(defun c:hipl nil
(sssetfirst nil
 (ssget "_X" '((0 . "*POLYLINE,SPLINE")
     (-4 . "<NOT")(-4 . "<OR")
     (70 . 1) (70 . 9)(70 . 129)
     (-4 . "OR>")(-4 . "NOT>")
 )(princ)
If we take the code Tharvat, and assume that it is sometimes not correctly closed polylines (same start and end), here:
 (vl-load-com)
 (if (setq
ss (ssget "_x"
     (if (or
    (equal (vlax-curve-getStartPoint sn)
	   (vlax-curve-getEndPoint sn)
(ssdel sn ss)
 (sssetfirst nil ss)
hmmmn makes me wonder what the OP is planning to do with the selected plines
perhaps this:
(defun c:hipl ( / p b e)
(vl-load-com)
(if (setq p   (ssget "_X" '((0 . "*POLYLINE,SPLINE")
(repeat (setq b (sslength p))
 	(setq e (ssname p (setq b (1- b))))
 		(if (equal (vlax-curve-getStartPoint e)
	           (vlax-curve-getEndPoint e))
	  	(vla-put-closed (vlax-ename->vla-object e) :vlax-true)
Closes plines with the same start and end point.
(defun c:selectopenpolylines ( )
   (sssetfirst nil (ssget "_X" '((0 . "*POLYLINE") (-4 . "<NOT") (-4 . "&=") (70 . 1) (-4 . "NOT>"))))
(Defun C:ChkPl(/ old_var plcntr pllen ssnme ent)
 (setq old_var(Getvar "CMDECHO"))
 (setvar "CMDECHO" 0)
 (if (setq plset(ssget "x" '((0 . "POLYLINE"))))
     (setq plcntr 0)
     (setq pllen(sslength plset))
     (repeat pllen
(setq ssnme(ssname plset plcntr))
(setq Ent  (entget ssnme))
(if (/= (cdr (assoc 70 ent)) 9)
  (Vl-Cmdf "CHPROP" ssnme "" "C" "1" "")
(setq plcntr(1+ plcntr))
 (princ "\nNo POLYLINES Found in Drawing!:")
 (setvar "CMDECHO" old_var)
Happy Computing :)
:notworthy:
Thank you all for the help
