cadamrao Posted November 9, 2012 Share Posted November 9, 2012 Sir, I have a lisp to printout layout drawing;it works :geek:greate to print single layout; but I need to printout all layouts in my drawing.Please revised the attached lisp to print all layouts.Currently we are using server based printer A3 (FX ApeosPort-IV C5575 L13) and need to print all layouts as per my pagesetup A3 or A1 or.... Advance thanks venki layout plot.lsp Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted November 9, 2012 Share Posted November 9, 2012 Why not just use the PUBLISH command, or select all the layouts and right click and choose Publish? Quote Link to comment Share on other sites More sharing options...
cadamrao Posted November 9, 2012 Author Share Posted November 9, 2012 Why not just use the PUBLISH command, or select all the layouts and right click and choose Publish? Hi I know the PUBLISH command;but it need this more faster. Thanks Quote Link to comment Share on other sites More sharing options...
maratovich Posted November 9, 2012 Share Posted November 9, 2012 We use it. Try, can to you will approach. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 9, 2012 Share Posted November 9, 2012 Have a look at this post http://www.cadtutor.net/forum/showthread.php?69132-Printing-LISP-Help...&highlight=Printing-LISP there are others poted here as well for this method just change the PDF to your printer name Quote Link to comment Share on other sites More sharing options...
pmxcad Posted November 10, 2012 Share Posted November 10, 2012 i use this script: (foreach lay (layoutlist) (setvar "CTAB" lay) (command "_PLOT" "N" "" "" "" "" "Y" "")) make sure all the page setups are set. PmxCAD Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 12, 2012 Share Posted November 12, 2012 pmxcad, Please use CODE TAGS for code snippets. Quote Link to comment Share on other sites More sharing options...
BrianTFC Posted November 12, 2012 Share Posted November 12, 2012 Heres is what we use where i work, it works great. the good thing is that the pages don't have to be sets. it also doesn't print the model tab. (defun c:Tab ( / ) (foreach layoutname (vl-remove "Model" (layoutlist)) (command "._layout" "set" layoutname) (command "-plot" "yes" layoutname "TFC-ENGXER6204.pc3" "Arch C (18x24 in.)" "Inches" "LANDSCAPE" "NO" ;PLOT UPSIDE DOWN "LAYOUT" "1:1" "0.00,0.00" "YES" ;PLOT WITH PLOTSYTLES "MONOCHROME.CTB" "NO" ;PLOT WITH LINEWEIGHTS "NO" ;SCALE LINEWEIGHTS WITH PLOT SCALE "YES" ;PLOT PAPER SPACE LAST "NO" ;REMOVE HIDDEN LINES "NO" ;WRITE THE PLOT TO A FILE "NO" ;SAVE CHANGES TO LAYOUT "YES");PROCEED WITH PLOT ) (princ) ) Quote Link to comment Share on other sites More sharing options...
