lewissheen24 Posted January 16, 2013 Share Posted January 16, 2013 Hello, I am having difficulty importing coordinates into AutoCAD 2011. The formats i am trying import are CSV and TXT files. Is there any quick ways to do this? Quote Link to comment Share on other sites More sharing options...
Organic Posted January 16, 2013 Share Posted January 16, 2013 See http://www.lee-mac.com/ptmanager.html Quote Link to comment Share on other sites More sharing options...
Murph_map Posted January 17, 2013 Share Posted January 17, 2013 An old post but still works http://map3d.wordpress.com/2006/06/25/points-from-a-text-file/ Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 18, 2013 Share Posted January 18, 2013 Bringing them in is easy what do you want to do with them ? Point, labels, co-ords, labels, surface model ?? Quote Link to comment Share on other sites More sharing options...
lewissheen24 Posted January 18, 2013 Author Share Posted January 18, 2013 BIGAL - I would like the coordinates to be marked by a cross and have a label next to them, so when i set the points out i know which is which. Also would you know how to export coordinates of points that i pick the centre of.ideally so i can put them into a excel sheet and download them to the survey instrument. I am a AutoCAD novice so any help would be greatly appreciated, and depending how complicated the process is i may need a step by step guide. Quote Link to comment Share on other sites More sharing options...
Organic Posted January 18, 2013 Share Posted January 18, 2013 What you want to do can be easily done in any survey software package, although AutoCad is not the right tool for the job. You would be better off using AutoCad Civil 3D or any other survey/civil program for importing/exporting points from equipment, survey calcs, creating DTMs etc. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 19, 2013 Share Posted January 19, 2013 Best way is if you want a cross and a lable is to use a block with attributes the advantage is then you can do step 2 very easy find certain block points and export the data CSV this you can read straight into most instruments. Have a look at Lee's ptmanager first and if it doesn't do what you want come back, also let us know if it does meet your needs. Threre is heaps of point stuff out there. Quote Link to comment Share on other sites More sharing options...
lewissheen24 Posted January 19, 2013 Author Share Posted January 19, 2013 (edited) Ok cheers. I have sorted how i show the x,y coordinates, so they show like this: X = ........ Y = ........ I am trying to do the lee-mac - writecsv http://www.lee-mac.com/writecsv.html , but it is coming up with an error. Select objects: 1 found Select objects: ; error: no function definition: LM:LST->CSV All i have done is added this code to the command bar. (defun LM:WriteCSV ( filename data / file sep ) (if (setq file (open filename "w")) (progn (setq sep (ascii (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))) (foreach line data (write-line (LM:lst->csv line sep) file) ) (close file) t ) ) ) any help would be good Edited January 28, 2013 by SLW210 Code TAGS!! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 21, 2013 Share Posted January 21, 2013 Please read the CODE POSTING GUIDELINES and place your Code in Code Tags. Not sure what you mean by "added this code to the command bar". You should just need to save the .lsp to a folder in AutoCAD's search path then load. Here is a Lee Mac Tutorial-- How to Run an AutoLISP Program Quote Link to comment Share on other sites More sharing options...
lewissheen24 Posted January 21, 2013 Author Share Posted January 21, 2013 Got it working finally. thanks guys. Is there any way i can export a coordinate with a name so it appears like this: Name.....X........Y........Z......... As always any help would be good. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 22, 2013 Share Posted January 22, 2013 A csv file can be in any format POINT X Y Z DESCRIPTION PENZ PNEZD ENZD You can start with simpler import points routine and customise one to suit your needs but have you really looked at the options within Lee-mac's point manager particuarly the block option. Quote Link to comment Share on other sites More sharing options...
NEXTMARCUS Posted January 22, 2013 Share Posted January 22, 2013 Try this post: http://www.cadtutor.net/forum/showthread.php?72677-Import-coordinates-from-a-text-file-txt-(sdr-csv)-in-AutoCAD its a program made by Geobuilder. Sorry about my very bad english Quote Link to comment Share on other sites More sharing options...
lewissheen24 Posted January 27, 2013 Author Share Posted January 27, 2013 BIGAL How do you export x y name then? And how do you import x y name? Could you provide indepth instructions? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 27, 2013 Share Posted January 27, 2013 You need to post a picture/dwg of what you want it can all be done. Quote Link to comment Share on other sites More sharing options...
lewissheen24 Posted January 28, 2013 Author Share Posted January 28, 2013 Importing.docxPlease see attached files, indepth instruction would be great.Exporting.docx Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 29, 2013 Share Posted January 29, 2013 1st Simplest way is to create a block with the marker and 3 attributes. Label, X & Y set up the way you want them to look In excel you can make the commands to create this all in one step Using contenate you join the relevant columns to make 1 single column Insert yourblockname x,y rotation scalex scaley scalez attrib1 attrib2 attrib3 Insert yourblockname x,y rotation scalex scaley scalez attrib1 attrib2 attrib3 Insert yourblockname x,y rotation scalex scaley scalez attrib1 attrib2 attrib3 This example inserts points just copy column F and paste onto command line. Do one manully and write down every question that autocad asks this what you need to duplicate. 2nd part export is even easier if you have made the blocks just use DATAEXPORT it will do it all for you. Quote Link to comment Share on other sites More sharing options...
lewissheen24 Posted January 29, 2013 Author Share Posted January 29, 2013 I can make the block with the attributes, the rest i can't understand . Your going to have to provide instruction step by step, not missing out any steps. Treat me like a idiot! Quote Link to comment Share on other sites More sharing options...
