How we can connect selected blocked with pline by lisp..........
Edited by hosyn
measure will do it. or divide
I hope this answered your question. I, for one, could not understand the question at all. If the problem is not yet solved, please post a DWG of precisely what you are trying to achieve.
thnx to bigal and neophibl
My question about when we located some block in drawing now need to command that when we selected that block after the run this command the block join together (.the base of this command
Can be lisp or macro ..):unsure:
So, it looks like you want to simply draw a pline with a single straight section whose endpoints are the insertion points of two selected blocks. Is that right? If so, a simple macro would do the trick. In AutoLISP you could have:
(command "pline" "ins" pause "ins" pause "")
For international applicability, I should have written it
(command "_.pline" "_ins" pause "_ins" pause "")
If I understand correctly (untested):
(defun c:l2b (/ lst)
 (if (and (AT:GetSel entsel "\nSelect first block: " (lambda (x / d) (if (eq (cdr (assoc 0 (setq d (entget (car x))))) "INSERT")
        (setq lst (list (assoc 10 d) (assoc 210 d)))
          (AT:GetSel entsel "\nSelect second block: " (lambda (x / d) (if (eq (cdr (assoc 0 (setq d (entget (car x))))) "INSERT")
        (setq lst (cons (assoc 10 d) lst))
     (entmakex (append '((0 . "LWPOLYLINE") (100 . "AcDbEntity") (100 . "AcDbPolyline") (90 . 2)) lst))
(defun AT:GetSel (meth msg fnc / ent)
 ;; meth - selection method (entsel, nentsel, nentselp)
 ;; msg - message to display (nil for default)
 ;; fnc - optional function to apply to selected object
 ;; Ex: (AT:GetSel entsel "\nSelect arc: " (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "ARC")))
 ;; Alan J. Thompson, 05.25.10
 (while
   (progn (setvar 'ERRNO 0)
          (setq ent (meth (cond (msg)
                                ("\nSelect object: ")
          (cond ((eq (getvar 'ERRNO) 7) (princ "\nMissed, try again."))
                ((eq (type (car ent)) 'ENAME)
                 (if (and fnc (not (fnc ent)))
                   (princ "\nInvalid object!")
 ent
Man, coding in Notepad, without formatting sucks. I can't believe I learned to code this way.
I didn't have any problem using it with my version!:rofl: But, then, I started out using edlin.:shock:
I'm VLIDE, all the way.
so thnx to all specially alanjet
this lisp is next to my idea.are there a way for selecting the blocks for 2 more with drag mouse on them (no one by one choosing) .:)
(defun c:l2b (/ ss)
 (if (and (setq ss (ssget '((0 . "INSERT")))) (eq (sslength ss) 2))
   (entmakex (list '(0 . "LWPOLYLINE")
                   '(100 . "AcDbEntity")
                   '(100 . "AcDbPolyline")
                   '(90 . 2)
                   (assoc 10 (entget (ssname ss 0)))
                   (assoc 10 (entget (ssname ss 1)))
                   (assoc 210 (entget (ssname ss 1)))
  • 1 year later...
Thanx to alanjt
Your code work great . Is there a way for selecting blocks with "ssget" .?? I change "entget" with "ssget" but don,t act well:( :(
hosyn you questions are to short you need to explain more, Alan Jt code is correct for selecting blocks they are known as "INSERT"
bigal i wanna select two block together with drag mouse ,i dont want select them one by one for that code.
Indead there are a lot of block in each drawing and i have to join them with ( pline or arc ) it's very easier than select them with drag mouse them instead select one by one . are there any suggestion for modify above code???:cry:
