Delete only plot configs that contain specific word in name...
First off, Hello everybody. I'm a long, long, time guest, first time participant. Thanks for the many years of assistance, but I know have one I can not figure out.
Now to my problem...
We recently upgraded the plotter in our office and I created new named plot configs to work with the new plotter. I've successfully setup a LISP which automatically retrieves all named plot configs from a specific .dwt and updates or adds them to each drawing is opened.
The part I'm have trouble with is getting rid of the old named plot configs. I've found routines that delete all, but I'm looking for one that deletes only ones with a certain printer name in the named config.
ie.
I want it to automatically delete the following configs:
24x36-OceTDS400
36x48-OceTDS400
11x17-RICOH
8.5x11-RICOH
But leave the following alone:
24x36-hpT3500
36x48-hpT3500
11x17-LANIER
8.5-LANIER
So, a routine that deletes all named configs with "OCE" or "RICOH" in them but leaves all others alone would do the job. I've looked around quite a bit today and did not find anything that works quite like this. If anybody has something similar or could point me in the right direction, I'd be greatly appreciative.
Thanks Again!
Welcome to CADTutor.
In AcadDoc.lsp, add a function that iterates the ActiveDocument Object's PlotConfigurations Collection, deleting those that match... Posting from an iPhone, and going from memory here, so forgive any code errors Haha:
(defun _DeletePlotConfigurations (acDoc)
 (vlax-for x (vla-get-plotconfigurations acDoc)
   (if (wcmatch (strcase (vla-get-name x)) "*OCE,*RICOH")
     (vla-delete x)
(_DeletePlotConfigurations (vla-get-activedocument (vlax-get-acad-object)))
... That will handle getting rid of unwanted named Page Setups, but setting one as active will require something like this:
http://forums.augi.com/showthread.php?80461-Page-Setup-Manager&p=1219546&viewfull=1#post1219546
(foreach layoutname (layoutlist)
 (vla-SetActivePageSetup layoutname “[color="red"]YourPageSetupName[/color]”)
... Both of which, will work with ObjectDBX.
Cheers
Edited by BlackBox
Apparently I didn't look hard enough.
Thank you BlackBox. I too am mobile at the moment, but this looks to be exactly what I need. Ill post here again once I test it out and let you know if you've solved my problem.
  • 1 month later...
BlackBox,
Thank you for your help last month. The code you provided help me clean up our plotting environment quite a bit. Requests for my assistance with plotting have dropped substantially also.
Thanks Again
BlackBox,
Thanks Again
You're welcome, TheMadCADer; I'm happy to help. :beer:
Cheers
