ILoveMadoka Posted November 17, 2009 Posted November 17, 2009 I have a routine that adds parenthesis around text objects. I don't know how to modify this code to include MTEXT, DIMENSIONS & MULTILEADER objects. (Any other text type objects??) I would love to have a more efficient coded version but first I'd like to see how my code would be modified to include these other objects. (I'm still learning..) (DEFUN c:PT (/ ss len count ent text) (SETVAR "CMDECHO" 0) (COMMAND "UNDO" "M") (PROMPT "\nAdds Parenthesis round selected text: ") (setq olderr *error* *error* ULERR) (PROMPT "\nSelect text: ") (SETQ SS (SSGET) LEN (SSLENGTH SS) COUNT 0) (WHILE (NOT (EQUAL LEN COUNT)) (SETQ ENT (ENTGET (SSNAME SS COUNT))) (IF (EQUAL (CDR (ASSOC 0 ENT)) "TEXT") (PROGN (SETQ TEXT (CDR (ASSOC 1 ENT)) TEXT (STRCAT "(" TEXT ")" ) ENT (SUBST (CONS 1 TEXT) (ASSOC 1 ENT) ENT)) (ENTMOD ENT))) (SETQ COUNT (1+ COUNT))) (PRINC)) Thank you guys again for not only what you've helped me with but for all the code you write! It's a bit overwhelming... Thanks again!! Quote
fixo Posted November 17, 2009 Posted November 17, 2009 I have a routine that adds parenthesis around text objects. I would use something like this (defun c:atp (/ count en ent len ss text) (command "._undo" "_be") (prompt "\nAdds parenthesis round selected text: ") (setq ss (ssget (list (cons 0 "*TEXT,DIMENSION,MULTILEADER"))) len (sslength ss) count 0) (while (not (equal len count)) (setq ent (entget (setq en (ssname ss count)))) (cond ((wcmatch (cdr (assoc 0 ent)) "*TEXT") (setq text (cdr (assoc 1 ent)) text (strcat "(" text ")") ent (subst (cons 1 text) (assoc 1 ent) ent))) ((equal (cdr (assoc 0 ent)) "DIMENSION") (progn (setq text (cdr (assoc 1 ent)) text "(<>)" ent (subst (cons 1 text) (assoc 1 ent) ent)) )) ((equal (cdr (assoc 0 ent)) "MULTILEADER") (progn (setq text (cdr (assoc 304 ent)) text (strcat "(" text ")") ent (subst (cons 304 text) (assoc 304 ent) ent)) )) ) (entmod ent) (setq count (1+ count)) ) (command "._undo" "_e") (princ) ) ~'J'~ Quote
ILoveMadoka Posted November 17, 2009 Author Posted November 17, 2009 Thanks!! Works Perfect!!! Now how about the high-end coded version in v-lisp or C#? It's a good learning tool to be able to compare simple lisp to the other language versions. Thanks so much!!! Quote
ILoveMadoka Posted November 17, 2009 Author Posted November 17, 2009 Thanks! If you get a chance it would be appreciated!! We use parenthesis around dimension to designate that they are approximate. (It's their standard) Everwhere else we used a tilde. I don't get to make the rules... I just have to draft by them!! (^_^) I'll try to figure out how to add the dimensions. If I can't figure it out I'll bug you again... Thank you again! Quote
fixo Posted November 17, 2009 Posted November 17, 2009 Thanks!! Works Perfect!!! Now how about the high-end coded version in v-lisp or C#? It's a good learning tool to be able to compare simple lisp to the other language versions. Thanks so much!!! Here is VLisp version too (defun C:Par (/ *error* adoc axss obj_type) (defun *error* (msg) (if (vl-position msg '("console break" "Function cancelled" "quit / exit abort" ) ) (princ "Error!") (princ msg)) (vla-startundomark (vla-get-activedocument (vlax-get-acad-object) ) ) ) ;;main part (setq adoc (vla-get-activedocument (vlax-get-acad-object) ) ) (vla-startundomark adoc) (setq axss (vla-get-pickfirstselectionset adoc)) (vla-clear axss) (vla-selectonscreen axss (vlax-safearray-fill (vlax-make-safearray vlax-vbinteger '(0 . 4)) '(-4 0 0 0 -4)) (vlax-safearray-fill (vlax-make-safearray vlax-vbvariant '(0 . 4)) '("<OR" "*TEXT" "DIMENSION" "MULTILEADER" "OR>") ) ) (vlax-for obj axss (setq obj_type (vla-get-objectname obj)) (cond ((wcmatch obj_type "*Dimension") (vla-put-textoverride obj "(<>)")) ((wcmatch obj_type "*Leader,*Text") (vla-put-textstring obj (strcat "(" (vla-get-textstring obj) ")")) ) ) ) (princ) ) (vl-load-com) This would be pretty easy to write it on C# or VB.NET Here is a good point to start: http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html ~'J'~ Quote
fixo Posted November 17, 2009 Posted November 17, 2009 Thanks!! Works Perfect!!! Now how about the high-end coded version in v-lisp or C#? It's a good learning tool to be able to compare simple lisp to the other language versions. Thanks so much!!! Here is C# version based on Adesk guide Tested slightly using System; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.DatabaseServices; using AcDb = Autodesk.AutoCAD.DatabaseServices; using acadApp = Autodesk.AutoCAD.ApplicationServices.Application; using Autodesk.AutoCAD.ApplicationServices; [assembly: CommandClass(typeof(SelectionCommands.FilterSelect))] namespace SelectionCommands { public class FilterSelect { [CommandMethod("FM")] public static void AddParenthesis() { // Get the current document Document doc = acadApp.DocumentManager.MdiActiveDocument; // Get the current document editor Editor ed = doc.Editor; // Get the current database Database db = doc.Database; using (Transaction tr = db.TransactionManager.StartTransaction()) { // Create a TypedValue array to define the filter criteria TypedValue[] ftype = new TypedValue[] { new TypedValue((int)DxfCode.Operator, "<OR"), new TypedValue((int)DxfCode.Start, "*TEXT"),//Text and MText new TypedValue((int)DxfCode.Start, "DIMENSION"), new TypedValue((int)DxfCode.Start, "*LEADER"),//Leader and MLeader new TypedValue((int)DxfCode.Operator, "OR>") }; // Assign the filter criteria to a SelectionFilter object SelectionFilter fltr = new SelectionFilter(ftype); // Request for objects to be selected in the drawing area PromptSelectionResult psr; psr = ed.GetSelection(fltr); SelectionSet sset = null; // If the prompt status is OK, objects were selected if (psr.Status == PromptStatus.OK) { sset = psr.Value; acadApp.ShowAlertDialog("Number of objects selected: " + sset.Count.ToString()); } else { acadApp.ShowAlertDialog("Number of objects selected: 0"); } // iterate through selected objects foreach (ObjectId id in sset.GetObjectIds()) { DBObject obj = (DBObject)tr.GetObject(id, OpenMode.ForRead); // catch object name string objname = obj.GetRXClass().Name; ed.WriteMessage("\n{0}", objname);// debug only try { switch (objname) { case "AcDbText": DBText txt = obj as DBText; txt.UpgradeOpen(); txt.TextString = "(" + txt.TextString + ")"; break; case "AcDbMText": MText mtx = obj as MText; mtx.UpgradeOpen(); mtx.Contents = "(" + mtx.Contents + ")"; break; case "AcDbLeader": Leader ld = obj as Leader; if (ld.AnnoType == AnnotationType.MText) { MText ldtxt = (MText)tr.GetObject(ld.Annotation, OpenMode.ForRead); if (ldtxt != null) { ld.UpgradeOpen(); ldtxt.UpgradeOpen(); ldtxt.Contents = "(" + ldtxt.Contents + ")"; } } break; case "AcDbMLeader": MLeader mld = obj as MLeader; if (mld.ContentType == ContentType.MTextContent) { MText mt = new MText(); mt.SetDatabaseDefaults(); mt.SetPropertiesFrom(mld.MText as Entity); mt.Contents = "(" + mld.MText.Text + ")"; mld.UpgradeOpen(); mld.MText = mt; } break; //varios object names: //AcDbRotatedDimension //AcDbAlignedDimension //AcDb2LineAngularDimension //AcDbRadialDimension //AcDbDiametricDimension //AcDbOrdinateDimension //AcDbArcDimension case "AcDbRotatedDimension": RotatedDimension rd = obj as RotatedDimension; rd.UpgradeOpen(); rd.DimensionText = "(<>)"; break; case "AcDbAlignedDimension": AlignedDimension ad = obj as AlignedDimension; ad.UpgradeOpen(); ad.DimensionText = "(<>)"; break; case "AcDbOrdinateDimension": OrdinateDimension od = obj as OrdinateDimension; od.UpgradeOpen(); od.DimensionText = "(<>)"; break; //etc. etc. } } catch (Autodesk.AutoCAD.Runtime.Exception ex) { acadApp.ShowAlertDialog(ex.Message); } } tr.Commit(); } //dispose transaction } } } ~'J'~ Quote
ILoveMadoka Posted November 18, 2009 Author Posted November 18, 2009 Thank you guys so much!! You're AWESOME!! Quote
