dear all i search for offset with same value and opposite direction
realy if i get that option it will save me more time .
thanx for all
  • Replies 27
  • Lee Mac
    10
  • wrha
    6
  • alanjt
    2
  • ksavoie
    2
So you want to offset the same distance in two directions at the same time?
Try this:
(defun c:dOff ( / *error* of undo doc ss )
 (vl-load-com)
 (defun *error* ( msg )
   (and undo (vla-EndUndomark doc))
       (princ (strcat "\n** Error: " msg " **")))
 (if (and (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE")))
          (setq of (getdist "\nSpecify Offset Distance: ")))
     (setq undo
       (not
         (vla-StartUndomark
           (setq doc
             (vla-get-ActiveDocument
               (vlax-get-acad-object)
     (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc))
       (mapcar
         (function
           (lambda ( o )
             (vl-catch-all-apply
               (function vla-offset) (list obj o)
         (list of (- of))
     (vla-delete ss)
     (setq undo (vla-EndUndoMark doc))
dear mr lee
most thanx for ur good suport
but plz could u help me in following request
IF I HAVE TOW LINE LIKE IT APPEAR IN ATTACHED JPG
I NEED BREAK OPTION WITH VARIABLES VALUE
FROM CENTER OF THAT LINE
AND CREATE IN THE CUT TOW LINES
PERPENDICULAR IN BETWEEN IT
THANX ALOT
I'm sure that you can do a bit of trimming - we do have to work for our money sometimes.. o:)
Mr Lee
In Double Offset Lisp Can I Add Option In That Lisp To Delet The Source Line Or No
Thanx
(defun c:dOff ( / *error* of undo doc ss flg )
 (vl-load-com)
     (initget "Yes No")
     (setq flg (eq "Yes" (getkword "\nDelete Original? [Yes/No] <No> : ")))
     (setq undo
       (not
         (vla-StartUndomark
           (setq doc
       (mapcar
         (function
           (lambda ( o )
             (vl-catch-all-apply
         (list of (- of))
       (and flg (vla-delete obj))
     (vla-delete ss)
Mr Lee
Thank You Very Much
Mr Lee I Have Last Thing I Need It I N That Lisp
In Option Delet Source Line I Need Cut Line Betwen New Offset Line .
Most Thanx
I don't understand what you mean. Why did you not ask that when you asked me to modify it previously?
Oh Sory Mr Lee Realy I Try To Improve That Lisp To Be Better .
What I Need Trim Space Between New Offset
Sir Lee,
i need i similar routine. i made a msg in another thread and here is the link
http://www.cadtutor.net/forum/showthread.php?t=47492&page=2
if you have spare time, can you (or anybody) modify it for me.
it is like this.
offset both side
delete the original pline
connect & join them to become one
and finally instead of specifying the offset distance,
distance between 2 parallel line will be specified.
tnx.
  • 3 months later...
hi...
this lisp lisp is realy great...
can you please do me a favor?
now layer option for object is "source"
can you please make it to "Current"
thanks
bijoy.vm
nice, as always awesome :D
why this doesn't work with RAY object?
i never used them but i'm just curious.
i modify this:
(ssget "_:L" '((0 . "ARC,CIRCLE,ELLIPSE,*LINE,RAY")))
but nothing
thanks
Thanks Kruuger,
Because the Ray object doesn't have an Offset method
Here is another version of the above, more akin to the normal offset command:
DoubleOffset V1-1.lsp
Edited by Lee Mac
FYI Lee, you cannot offset a 3DPolyline.
Thanks Alan, I'll see to the code :)
No problem. I just thought I'd give it a look. I was actually curious what was so different that you aren't just suggesting your Dynamic Offset routine.
I've averted from 'dynamic' programs - too much hassle for minimal practicality... (I've finally seen the light) - I suppose that's what you get from actually working in a DO for a period...
