I have a drawing with many level values (as text objects) on it. I want to use entmod to change the colour of the text object depending on whether it is above or below certain levels.
I need to replace (print "red") and (print "green") lines with entmod that does this - can someone help me finish this lisp routine please?
(defun c:levbound ()
;ask for lower and upper bounds
(setq lower (getreal "\nLower bound...?"))
(setq upper (getreal "\nUpper bound...?"))
;select text objects to be evaluated
(setq ss (ssget '((0 . "TEXT"))))
(setq l (sslength ss))
(setq c 0)
;evaluate each text object
(while (/= c l)
 (setq ent (ssname ss c))
 (setq elist (entget ent))
 (setq txt (cdr (assoc 1 elist)))
 (setq val (atof txt))
 ;if value lower than the lower bound
 (if (< lower val)
  ;***then change text object colour to red***
  (print "red")
  ;else, is it higher than the upper bound?
   (if (> upper val)
   ;***then change text object colour to green***
   (print "green")
(setq c (+ 1 c))
The color is stored under DXF code 62; you will need to check if isn't currently set as ByLayer.
(if (< lower val)
 (print "red")
 (entmod (if (assoc 62 elist)
          (subst '(62 . 1) (assoc 62 elist) elist)
          (cons  '(62 . 1) elist)))
Thank you Mircea, that works nicely.
I noticed I had my greater/less thans the wrong way round! :oops:
(defun c:levbnd ()
(setq c 0)
(while (/= c l)
 (if (< val lower )
  ;then change text object colour to red
   (if (> val upper )
(setq c (+ 1 c))
Glad to hear that my example it was useful to you! You're welcome!
