Please help me to make lisp How to draw circles into shape.
A quick answer is to use Array and just make the circles, possibly combined with a lisp pick a few pts and done.
One question the upright has the circles not quite the same as the horizontal section should they be more equal on the horizontal section ? this may require a section by section task ?
Are these concrete reo bars ?
Thought of a quick possible answer for a pline just offset add circle at each vertice, then divide the pline segments and place circle need some form of rule here max spacing. Your dwg 200 c-c but vert bit is 100 & 120
Already got conflicting answers as per screen grab need a set of rules supports my section by section approach
  • 2 weeks later...
2nd look at problem different approach pick two diagonal corners use rectang and work out the new offset pline explode use divide to create circle points & end points, this will take into account different shapes and islands. Just need some time.
