HELP:Advise on how to highlight text attribute in drawings base on text in excel file
In the drawing, there are door tags block with text attribute eg, 1-1, 1-2 .....
In excel, i have a column of door tags with text corresponding to the text in the drawing eg, 1-1 , 1-2......
In this excel i have highlighted or filter certain door tags eg, 2-55, 2-89
How best to highlight this corresponding doors in the drawing by way of lisp or scripts?
I am open to try different methods.
Thanks
If you can upload a sample drawing including the target attributed block with the excel file , I would write a program for you in one go to save time . :)
Thanks bro. :)
Will do it during my lunch & post it as soon as i can.
Firstly save as your Excel file to csv format to be able to select it with the following program cause the other Excel formats are not supported with getfiled function .
Secondly try the program and let me know :)
(defun c:test (/ ss s f o ex x)
 ;;    Tharwat 08.01.2014    ;;
 (cond
   ((not (setq
           ss
            (ssget
              "_X"
              (list '(0 . "INSERT") '(66 . 1) (cons 410 (getvar 'CTAB)))
    (alert "No Attributed Blocks found in drawing !!")
   ((and (setq f (getfiled "Select Excel file :"
                           (getvar 'DWGPREFIX)
                           "csv"
                           16
         (setq o (open f "r"))
    (read-line o)
    (while (setq x (read-line o))
      (setq l (cons (if (setq ex (vl-string-search
                                   x
                      (substr x
                              1
                              ex
                      x
                    l
    (close o)
    (setq s (ssadd))
      (mapcar '(lambda (a)
                 (if (member (vla-get-textstring a) l)
                   (ssadd sn s)
              (vlax-invoke
                (vlax-ename->vla-object
                  (setq sn (ssname ss (setq i (1- i))))
                'getattributes
 (sssetfirst nil s)
Did as instructed.
1. Saved excel as CSV
2. Open the drawing.
3. Load test.lsp
3. Ran test (selected the CSV file)
Command: (LOAD "D:/test.lsp") C:TEST
Command: TEST
Command:
Command: '_.zoom _e
Nothing happened though.
 (cond
   ((not (setq
           ss
            (ssget
              "_X"
                           (getvar 'DWGPREFIX)
                           "csv"
                           16
    (read-line o)
                                   x
                      (substr x
                              1
                              ex
                      x
                    l
    (close o)
    (setq s (ssadd))
                   (ssadd sn s)
              (vlax-invoke
                'getattributes
 (sssetfirst nil s)
I just realised when saved as CSV, all the colours are gone & the door text changed to date format. :(
Edited by vernonlee
Hi Tharwat
As Pmed, i await your revised code.
Thanks
Hi Tharwat
Thanks
Hi .
Try the modified program that should work with txt file format and here I uploaded the txt file for your kind test :)
(defun c:test (/ ss s f o ex x l i sn)
 (cond
   ((not (setq
           ss
            (ssget
              "_X"
                           (getvar 'DWGPREFIX)
                           "txt"
                           16
    (read-line o)
      (setq l (cons x
                    l
    (close o)
    (setq s (ssadd))
                   (ssadd sn s)
              (vlax-invoke
                'getattributes
 (sssetfirst nil s)
Door tags.txt
Edited by Tharwat
Variable localized
Thanks Tharwat.
I have tested it.
Generally it select all the tags that is reflected in your uploaded TXT file.
However, i notice that if i repeat the command with with a TXT file that contain a different set of tags, it will still select the tags base on the first TXT.
I than close & reopen the drawing file and did the command but base on the 2nd TXT file, it did only select the specific tags. I then repeat the command base on your uploaded TXT file & it selected the tags as per your uploaded TXT file.
Hope you could solve it.
Hi .
 (cond
   ((not (setq
           ss
            (ssget
              "_X"
                           (getvar 'DWGPREFIX)
                           "txt"
                           16
    (read-line o)
      (setq l (cons x
                    l
    (close o)
    (setq s (ssadd))
                   (ssadd sn s)
              (vlax-invoke
                'getattributes
 (sssetfirst nil s)
I am sorry , one variable is not localized which is the most important one .
Replace this part or add the variable ( l ) as shown below .
(defun c:test (/ ss s f o ex x [color=red][b]l[/b][/color] )
Thanks Tharwat.
It now works correctly.
Just wanted to clarify the following:-
1) which part of the lisp code do i include the 1st line for the TXT file? ( I could not figure it out looking at the code :oops:)
2) Is there a limit to how many lines it will lookup to?
Thanks
Thanks Tharwat.
Thanks
I modified the program and you can jump to it from HERE
No limitation , it is open .
Hi Tharwat,
The modified lisp still will not select tag from the first line of the TXT.
I tried the program with the txt file that I have attached earlier and it works as expected , but if you are using another drawing or another txt file , that is a thing that I can not judge on .
Hi Tharwat.
I used the same drawing. The TXT file is also the same as per what you uploaded.
I just delete the first line "THIS IS THE DOOR TAG THAT TALLY WITH THE DRAWINGS" & "1-1" become the first line. but when i ran it, 1-1 on the drawing is not selected.
If so , just delete the following part from the program .
(read-line o)
(read-line o)
Great. That did the trick.
Thanks bro. :)
