Finetuning Excel - Autocad linking
Hi All,
I haven't got a problem as such, it's more that I get a little miffed at autocad at times. This is because I got serveral (20) nice links between autocad and excel (all in the same excel file and even the same sheet; just 20 different ranges). I did this by doing paste special -> excel link 20 times for the ranges I wanted to show in the drawing. so far so good, right?
Only every time someone else opens the drawing he/she has to answer the "update from source" (I don't know if I translated that correctly) question 20 times, because there are 20 OLE links.
Now, the question is: is there a method of combining those 20 OLE links to just one, since it is essentially all from the same source?
thank you all in advance!
