Hello everyone... Forgive me, but it's been a while since I've done any coding that really works with text files, but I was curious how I could search an entire text file (256 lines plus...) for a specific piece of text that has already been supplied through a variable? I know that I can go line by line, but I am not sure how to get it to stop and basically read the entire line on which the variable has been found. Any ideas or help?
In vb it would go like this
Dim sNextLine As String
dim sSearchFor as string
Open sFilePath For Input As #1
Do Until EOF(1)
   ' read one line at a time from the file, assign to sNextLine
   Line Input #1, sNextLine
   If InStr(sNextLine, sSearchFor) > 0 Then
       "DO WHAT YOU WANT HERE WITH sNextLine"
   End If
Loop
Close #1
I would love it being that simple, but I don't really know VB or VBNet... I haven't been able to take the leap over yet any ideas for lisp?
' heres a little code to get you started. It comes with a test sub. You pass it the string you wish to find, the full file/path name of the TEXT file you want to search, and whether the search is case sensitive or not.
Theres plenty here that it DOESNT do, but hey, what do you want, for free? :P
'---- snip------------------------------------------
Sub test()
   Dim retStr As String
   retStr = LineFromText("timeout", "c:\boot.ini", False)
   MsgBox "*" & retStr & "*"
End Sub
Function LineFromText(strSearchText As String, strFileSpec As String, MatchCase As Boolean) As String
   ' Opens a TEXT file (only!) and searches line by line for a line of text
   ' that contains the search string. Quits on the first line it finds.
   ' Returns the entire line of text, or "" if none found. If MatchCase is True,
   ' the capitalization must be exact.
   Dim FileExists As String
   Dim NextFile As Integer
   Dim FileString As String
   Dim txtSearchStr As String
   FileExists = Dir$(strFileSpec)  ' see if file actually exists on disk
   If FileExists = "" Then Exit Function
   ' Put our search string into a variable
   txtSearchStr = strSearchText
   If MatchCase = True Then txtSearchStr = UCase$(txtSearchStr)
   NextFile = FreeFile  ' get next available File handle
   Open strFileSpec For Input As #NextFile
   Do
       Line Input #NextFile, FileString
       If MatchCase = True Then FileString = UCase$(FileString)
       ' now check to see if our search string is in this line...
       If InStr(FileString, txtSearchStr) Then LineFromText = FileString: Exit Do
   Loop Until EOF(NextFile)
   Close #NextFile
End Function
any other ideas that use lisp? Sorry, it is kinda a retro fit...on top of my lack of vba.
Lisp solution:
(defun c:tfind(/ fTxt tFile fDscr lCnt mCnt cLn *error*)
 (defun *error*()
    (if fDscr(close fDscr))
   ); end of *error*
 (if
   (and
    (/= ""(setq fTxt(getstring T "\nSpecify text to find: ")))
    (setq tFile(getfiled "Select text file" "" "txt" 4))
    ); end and
   (if
     (setq fDscr(open tFile "r"))
(setq lCnt 1 mCnt 0)
(while(setq cLn(read-line fDscr))
  (if(wcmatch cLn(strcat "*" fTxt "*"))
      (textscr)
      (setq mCnt(1+ mCnt))
      (princ(strcat "\nText specified found in line ["(itoa lCnt)"] "))
      (princ(strcat "\n\"" cLn "\" "))
      (getkword "\nPress Enter to continue... ")
      ); end progn
    );end if
  (setq lCnt(1+ lCnt))
  ); end while
(princ(strcat "\n"(itoa mCnt) " strings found. "))
(close fDscr)
); end progn
     (princ "\n<!> Can't to open file specified! <!> ")
     ); end if
   ); end if
 ); end of c:tfind
