cameroon95 Posted November 10, 2008 Share Posted November 10, 2008 As the title says, I have a model which has came over from invenntor in a single piece(attached if you will) and I need to colour certain parts a different colour from the rest. Is this possible to do? Or Is it possible to un-attach an object? Split it up into user-defined regions? cheers Quote Link to comment Share on other sites More sharing options...
cameroon95 Posted November 10, 2008 Author Share Posted November 10, 2008 Scratch that, I just found the tool!!! Quote Link to comment Share on other sites More sharing options...
Cad64 Posted November 10, 2008 Share Posted November 10, 2008 Which tool did you use? I was going to suggest using a Multi/Sub-Object material. Quote Link to comment Share on other sites More sharing options...
cameroon95 Posted November 10, 2008 Author Share Posted November 10, 2008 I deattached the faces using the face select in editable mesh. Then selected the de-attached parts and coloured them separately. I really like the method that you advised though, I shall try that later today! Quote Link to comment Share on other sites More sharing options...
