meecpc Posted January 5, 2009 Posted January 5, 2009 Hi all, Using Acad 2006. We have a certain block the has a dot line type. When I insert it in one drawing the line type looks fine. When I try it in another the line type is too spaced out. The linetype scaling is 1 for both drawings. Why the difference? Thanks Bill Quote
ReMark Posted January 5, 2009 Posted January 5, 2009 Is the block being inserted at the same scale in both drawings? Quote
A1DWG Posted January 6, 2009 Posted January 6, 2009 meecpc, I think it might be the drawing you are inserting the block into. New drawings can be created in either metric or imperial units, from which AutoCAD uses different definitions for the linetypes. (varies by x25 - mm to the inch) Use the measurement commmand and set both to either 1 for metric, or 0 for imperial. Quote
meecpc Posted January 6, 2009 Author Posted January 6, 2009 Both are set to 0. Any other ideas? Thanks Quote
A1DWG Posted January 6, 2009 Posted January 6, 2009 try reloading the linetypes, and confirm overwriting if they are already present. If that doesnt work, delete the block frmo the drawings, purge and reinstall, iff all else fails post a copy of the drawings and I can have a quick look. Quote
meecpc Posted January 6, 2009 Author Posted January 6, 2009 A1DWG, I bow to you this morning in everlasting gratitude! Thanks a bunch bud. This site is the best for answers. Quote
stevsmith Posted January 26, 2009 Posted January 26, 2009 This used to happen to me as well. I over came it by cutting the entire drawing to the clipboard and insert it into a new drawing and overwite the old dwg. It seemed to happen when I went into block editor and it wouldn't regen in the main drawing till i done the above. Quote
