entering a dimension line manually
How does one enter a dimension on a dimension line manually?
Is it that you want to override the value AutoCAD is giving you?
Using the Text (T) option:
Command: _dimlinear
Specify first extension line origin or
Specify second extension line origin:
Non-associative dimension created.
Specify dimension line location or
[Mtext/Text/Angle/Horizontal/Vertical/Rotated]: t
Enter dimension text : 23.1
there is almost no reason whatsoever for doing so
It's mostly a hanging offence
dimensions should accurately represent what you have on your drawing which should be drawn accurately using such aids as snaps, never eye-in a line
if scale is the problem you have with your dimensions, it's the dimstyle you need to alter - set the scale appropriately
I guess Johnart doesn't want to tell us.
Thank you Remark and Strix for your help. Here is my problem....I have limited access to resources and I am trying to learn Autocad2009 from a trial copy, which means I now have 28 days to learn what I can. Its a long story but I use to be a structural draftsman during the days of paper and pencil...now I need to learn it for a job. [ moved to new thread: http://www.cadtutor.net/forum/showthread.php?t=31048 ] I know my questions are very basic and I apologize for my ignorance but any help you can give me would be greatly appreciated...if I could use you for a resource...provided that you are willing that would be great..I'll understand if you don't wish to participate.
Best Regards...........John
I've just moved your other questions to their own thread to save confusion here :thumbsup:
if you've had a browse about you'll find that we try to keep threads very much on topic with their title so they stay as a searchable resource to other users :)
... similar to CAD draughting really - whilst accuracy and some artistic skills are necessary with pencil or ink, a methodology and good housekeeping are the best way to ensure a useable drawing file :wink:
1st..explode the dimensions..
2nd..erase the annotations..
3rd..plot yer drawings..
4th..manually fake the dimensions..
bad idea gonzo....very bad..
Johnart: I am more than willing to try and assist you. However, you must answer the questions that we put to you directly and with as much detail as you can muster. I have yet to see your answers to previously asked questions.
What is it exactly that you are trying to accomplish re: manually entered dimensions? Note that one of the benefits to using a CAD program is it can be very specific with things like dimensions and angles and such.
Are you using Quick Dimensions by any chance?
..out in the real world is very important not to forget yer manual drawing skills......
i experience working with (site) contractors when they send me RFI'S
(request for information) really fast answers..i have to use the old fax machine to answer....and mix a-cad /and manual drafting....
my boss was happy and they where happy.............
quote..." be part of the solution not part of the problem"
(somebody)
