Can anyone help me with this lisp? {stubs.lsp}
Hey i left a previous thread and here it is a little simpler.
This is a routine that will make a table it has one Header and the rest of the cells are for calculations. The table has one column and 15 rows. But when i execute the command the calculations are plotted in decimal form. If you check the properties of this table the cells are not data cells. What can i put in this routine to make these data cells? This is the biggest problem right now. so i need to get it to execute in feet, inches, and fractions. Then i would like someones expertise on getting the table to insert at the right size. Like based on the dimscale factor. Can Anyone Help?
(DEFUN C:STUBS (/ WIDE COL ROW TB HIGH PT VA VO VM)
 (SETQ PT (VLAX-3D-POINT (GETPOINT)))
 (SETQ VO (VLAX-GET-ACAD-OBJECT))
 (SETQ VA (VLA-GET-ACTIVEDOCUMENT VO))
 (SETQ VM (VLA-GET-MODELSPACE VA))
 (SETQ ROW 15)
 (SETQ COL  1)
 (SETQ HIGH 0.3875)
 (SETQ WIDE 1.25)
 (SETQ TB (VLA-ADDTABLE VM PT ROW COL HIGH WIDE))
 ;(VLA-PUT-REGENERATETABLESUPPRESSED TB :VLAX-TRUE)
 (vla-settext tb 0 0 "STUBS")
 (vla-settext tb 1 0 (GETDIST "What is the first stub dimension?"))
 (vla-settext tb 2 0 "=A2*2")
 (vla-settext tb 3 0 "=A2*3")
 (vla-settext tb 4 0 "=A2*4")
 (vla-settext tb 5 0 "=A2*4")
 (vla-settext tb 6 0 "=A2*5")
 (vla-settext tb 7 0 "=A2*6")
 (vla-settext tb 8 0 "=A2*7")
 (vla-settext tb 9 0 "=A2*8")
 (vla-settext tb 10 0 "=A2*9")
 (vla-settext tb 11 0 "=A2*10")
 (vla-settext tb 12 0 "=A2*11")
 (vla-settext tb 13 0 "=A2*12")
 (vla-settext tb 14 0 "=A2*13")
 (vla-settext tb 15 0 "=A2*14")
 ;(vla-put-RegenerateTableSuppressed tb :vlax-TRUE )
 );_ end
My Question is, is there anyway to get the header row in a certain text style and the other cells in a different one?
Try edited code, not sure about
how it will works
Change text styles names before running
(defun C:STUBS (/ col count dis pr prec pt row strdis tb va vm vo)
 (setq pt (vlax-3d-point (getpoint "\nPick Insertion Point: ")))
 (setq vo (vlax-get-acad-object))
 (setq va (vla-get-activedocument vo))
 (setq vm (vla-get-modelspace va))
 (setq row 16)
 (setq col  1)
 (setq dis (getdist "\nWhat Is The First Stub Dimension? : "))
 (initget 6)
 (setq prec (getint "\nWhat Is The Number Of Decimal Places? : "))
 (setq pr (getvar "LUPREC"))
 (setvar "LUPREC" prec)
 (if (not (vl-string-search "." (setq strdis (rtos dis 2 2))))
     (setq strdis (strcat strdis ".00")))
 (setq tb (vla-addtable vm pt row col 1 1))
 (vla-put-titlesuppressed tb :vlax-false)
 (vla-put-headersuppressed tb :vlax-true)
 (vla-put-RegenerateTableSuppressed tb :vlax-true)
 (vla-put-vertcellmargin tb 0.1)
 (vla-put-horzcellmargin tb 0.25)
 (vla-setrowheight tb 0 0.4825)
 (vla-setcolumnwidth tb 0 2.4)
 (vla-settextstyle tb actitlerow "Romans");title text style
 (vla-settextstyle tb acdatarow "Standard");data rows text style
 (vla-settextheight tb actitlerow 0.27);title text height = 0.27
 (vla-settextheight tb acdatarow 0.21);other cells text height = 0.21
 (vla-setalignment tb actitlerow acmiddlecenter);title alignment
 (vla-setalignment tb acdatarow acmiddleleft);data cell alignment
 (vla-settext tb 0 0 "STUBS");title text
 (setq count 1)
 (while (< count row)
 (vla-setrowheight tb count 0.3875)
 (if (=  count 1)
 (vla-settext tb count 0 strdis)
 (vla-settext tb count 0 (strcat "= A2*" (itoa count)))
 (setq count (1+ count)))
 (alert (vl-princ-to-string (vla-getcellformat tb (1- count) 0)))
 (vla-put-RegenerateTableSuppressed tb :vlax-false)
 (setvar "LUPREC" pr)
 );_ end
(vl-load-com)
~'J'~
Hey i am very appreciative about your help. i Have one question about modifing this code. Its still in decimal for is there anyway to put in the vla-setdatatype function to make all of the rows architectual and set the current precision to 1/16? anymore help will be greatly appreciative!!!
Ok well i got all of that figured out. so now my only problem is getting it to insert to the right dimscale
Try edited version
(defun C:STUBS	(/ col count dis dmz lpc lup pt row strdis tb va vm vo)
 (setq row 16)
 (setq col 1)
 (setq lup (getvar "lunits"))
 (setvar "lunits" 4)				  ; architectural units
 (setq lpc (getvar "luprec"))
 (setvar "luprec" 4)				  ;precision 1/16"
 (setq dmz (getvar "dimzin"))
 (setvar "dimzin" 1)				  ;includes both feet and inches for primary unit
 (setq strdis (rtos dis 4 3))
 (vla-setcolumnwidth tb 0 2.725)
 (vla-settextstyle tb actitlerow "Romans")	  ;title text style
 (vla-settextstyle tb acdatarow "Standard")	  ;data rows text style
 (vla-settextheight tb actitlerow 0.27)	  ;title text height = 0.27
 (vla-settextheight tb acdatarow 0.21)		  ;other cells text height = 0.21
 (vla-setalignment tb actitlerow acmiddlecenter) ;title alignment
 (vla-setalignment tb acdatarow acmiddleleft)	  ;data cell alignment
 (vla-settext tb 0 0 "STUBS")			  ;title text
 (setq count 1)
   (if	(= count 1)
     (vla-setcellformat tb count 0 "%lu4%pr4"));lu4 - format in architectural units, pr4 - precision is 1/16"
     (vla-settext tb count 0 (strcat "= A2*" (itoa count)));lu4 - format in architectural units, pr4 - precision is 1/16"
 (setvar "luprec" lpc)
 (setvar "lunits" lup)
 (setvar "dimzin" dmz)
 ) ;_ end
(vl-load-com)
Forgot about, please, share your solution
with community
~'J'~
