Transformation Coordinates False (2D)
Hi, I am new in this forum (and also in Autolisp). I modified a code I saw here.
It transform polyline's coordinates
This is the code i found here:
(defun c:poly()
 (setq ps (entsel "Pick a polyline"))     ;Get a selection
 (setq pl (car ps))                           ;find the polyline
 (setq pll (entget pl))                       ;get it's entity list
 (setq new nil)                                ;create a new list
 (repeat (setq i (length pll))            ;Walk thru the list
   (if (= 10 (car (nth (setq i (1- i)) pll)))    ;If found a node...
       (setq x (cadr (nth i pll))                  ;extract the coords
         y (caddr (nth i pll))
       (setq x (+ x 100))                          ;do anything with
       (setq y (* 1.0 y))                         ;X and Y
       (setq new (cons (list 10 x y) new)) ;and add them to the new
     (setq new (cons (nth i pll) new))    ;If not a node, just add it
 (entdel pl)                                         ;delete the polyline
 (entmake new)                                  ;create a new one
And this is mine (it's only modified in the algorithm):
(defun c:poly()
       (setq x [color=Red](- (+ 327063.85 (* 0.9997106 x) (* 0.0229562 y) (* 0.00000000205 y y)) (* 0.00000000216 x x) (* 0.00000000008 x y))[color=Black])[/color] [/color]  ;do anything with
       (setq y [color=Red](- (+ 4457285.55 (* 0.9997092 y) (* 0.00000000034 x x) (* 0.00000000009 y y)) (* 0.00000000422 x y) (* 0.0229499 x))[/color])   ;X and Y
Well if you multiple and sum x-coordinate , the new one is ok. But there is something wrong in y-coordinate but I do not know what it is.
For example for a point (0,0), Excel (checked) gives (327063.85 4457285.55)
But with this code gives (327063.85 4449815.837)
Here is the functions for excel:
X=327063.85+0.9997106*x+0.0229562*y-0.00000000216*x*x+0.00000000205*y*y-0.00000000008*x*y
Y=4457285.55-0.0229499*x+0.9997092*y+0.00000000034*x*x+0.00000000009*y*y-0.00000000422*x*y
Can anyone help me?
Not sure if this is any different:
(setq y (- (+ (- 4457285.55 (* 0.0229499 x)) (* 0.9997092 y) (* 0.00000000034 x x) (* 0.00000000009 y y)) (* 0.00000000422 x y))
But to be honest, the LISP isn't particularly well-written, I might consider re-writing it :)
A better way of writing it to allow for a null selection and selection of wrong entity type:
(defun c:poly (/ pl plLst i x y new)
 (if (and (setq pl (car (entsel "\nPick a Polyline >  ")))
      (= "LWPOLYLINE" (cdr (assoc 0 (setq plLst (entget pl))))))
     (repeat (setq i (length plLst))
   (if (= 10 (car (nth (setq i (1- i)) plLst)))
       (setq x (cadr (nth i plLst)) y (caddr (nth i plLst))
             x (+ x 100.0) y (* y 2.0))
       (setq new (cons (list 10 x y) new)))
     (setq new (cons (nth i plLst) new))))
     (entdel pl)
     (entmake new))
   (princ "\n<!> No Polyline Selected <!>"))
 (princ))
Does this need another ) at the end of the line?
I've tried the ther one also but nothing. Any other idea?
Thanks for your interest
I 've checked it again and again but nothing.If I write first the algorithm of y-coordinate and then x-coordinate, the destination y-coord is ok but there is a wrong with x-coord
The problem is you are using the variables x & y for the initial coordinates & the transformed coordinates.
When the new x is calculated for point 0,0, the calculation is as intended as it correctly uses x=0 & y=0. But in the calculation for y, it uses the just calculated x=327063.85 instead of x=0.
Well I thought it might be that,but i 've done the calculation for y-coord (manually) with the new x-coord (x=327063.85) but the result is different than this .lsp gives.
Well I used your equation, put it in Excel, & I get the same answer as the lisp answer when x=327063.85 & y=0. So maybe aproblem with your manual method :)
But now I 've made a change in points parameters and I think it works.
Thanks for this advise CarlB and for the modified new code Lee Mac
Here is the final:
(defun c:poly()
       (setq [color=Red]E[/color] (- (+ 327063.85 (* 0.9997106 x) (* 0.0229562 y) (* 0.00000000205 y y)) (* 0.00000000216 x x) (* 0.00000000008 x y)))   ;do anything with
       (setq [color=Red]N[/color] (- (+ 4457285.55 (* 0.9997092 y) (* 0.00000000034 x x) (* 0.00000000009 y y)) (* 0.00000000422 x y) (* 0.0229499 x)))   ;X and Y
       (setq new (cons (list 10 [color=Red]E N[/color]) new)) ;and add them to the new
  • 1 year later...
Can we store temporary variables in the previous code?
For example
(setq E (- (+ 327063.85 (* 0.9997106 x) (* 0.0229562 y) (* 0.00000000205 y y)) (* 0.00000000216 x x) (* 0.00000000008 x y)))
if E = B1+B2
and B1=x(x+y) and B2=y(x+y)
I want first to calculate B1 and B2 and then calculate E. Can this be done?
  • 11 months later...
Well, CarlB & Lee Mac can you help me to modify the code, again?
How do we change it to transform not only polylines but also circles, arcs, lines etc..... How abouts all objects (including blocks and images) ?
