I have drawn some dashed lines in Model Space and adjusted the LTSCALE so that they appear the way I want them to. When I switch to Paper Space they appear as contnuous lines within the viewport. How do I make them appear the same as they do in Model Space?
Thanks.
Set PSLTSCALE = 0
I just noticed that you are using 2002. I don't know if that will work in 2002. I use it in LT 2009.
I spent hours trying to fix this a couple of weeks ago!!! Thnaks.
Funny, but this (PSLTSCALE = 0) doesn't work for me.....
Could be that someone has messed with your LTSCALE variable - but then if the lines look OK in model space, this would completely debunk my theory... :huh:
check the msltscale.
i posted a reactor a while back i wrote that will set the psltscale when you switch layouts, it was a modified version of my ltscale reactor (before msltscale). still need the psltscale reactor for opening older drawings. you are more than welcome to it.
here's the link:
http://cadtutor.net/forum/showthread.php?p=215235#post215235
just add the ltscale coding if you need that (setvar "ltscale" ##)
