Hi
Am wondering if someone can give me some advice in creating a selection set to automatically select title blocks (Only One per layout)
Namely
A1Title
A2Title
A3Title, etc.
My code iretates between layouts but at the moment has got a user input to select the block and I would like the code to automatically select the block and then scroll through layouts.
Have attached file for a better understanding.
Hope someone can help.
Project6.zip
Judging by your attachment, I'm guessing you're after VBA?
but in LISP:
(setq ss (ssget "X"
               (list (cons 0 "INSERT")
                     (cons 2 "A1Partners")
                     (if (getvar "CTAB")
                       (cons 410 (getvar "CTAB"))
                       (cons 67 (- 1 (getvar "TILEMODE")))))))
Thanks for reply
I am after VBA, have no knowledge of lisp unfortunately.
Regards
Streng
Thanks for reply
Regards
Streng
I thought that may be the case :)
I'll take a peek at this later today.
Here are some modifications that allow Layout processing without the need to manually iterate through them.
I may have inadvertently changed the output format – you’d be the best person to access that – but this should give you some additional options to play with.
Option Explicit
Dim objXL As Excel.Application
Private Sub CreateNewIssue()
Dim intCode(1) As Integer
Dim varData(1) As Variant
Dim layBlock As AcadBlock
Dim elem As AcadEntity
Dim cLay As AcadLayout
Dim Array1 As Variant
Dim RowNum As Long
Dim aCount As Long
Dim Workbook As Excel.Workbook
Dim getAcObj As AcadObject
Dim anExcelActiveWorkBook As Excel.Workbook
Dim anExcelActiveSheet As Excel.Worksheet
Dim Cust() As String
Dim col As Long
Dim row As Long
Dim DrgNo As Long
  ' To Create Drawing Register / Doc Issue Sheet
  'SummaryInfo
  RowNum = 1
  DrgNo = 1
  'Checks Excel Is Running (Using Function IsExcel Running)
  If Not IsExcelRunning() Then
     MsgBox "Problem starting Excel!"
     Exit Sub
  End If
  'Turns Screen Updating Off While Doc Issue Populates
  objXL.Application.ScreenUpdating = True   'To Be Changed To False Upon Completion
  intCode(0) = 0: varData(0) = "Insert"
  intCode(1) = 2: varData(1) = "*Partners"
  If AllSS(intCode, varData) > 0 Then
     For Each elem In ThisDrawing.SelectionSets.Item("TempSSet")
     Set layBlock = ThisDrawing.ObjectIdToObject(elem.OwnerID)
     Set cLay = layBlock.Layout
        If elem.HasAttributes Then
           Array1 = elem.GetAttributes
           objXL.Visible = True
           objXL.WindowState = 3
           Set anExcelActiveWorkBook = objXL.Workbooks.Add
           anExcelActiveWorkBook.Activate
           Set anExcelActiveSheet = anExcelActiveWorkBook.ActiveSheet
           'Puts Titles On Sheet 1 (i.e Project1, Project 2, etc)
           For aCount = LBound(Array1) To UBound(Array1)
              anExcelActiveSheet.Cells(RowNum, aCount + 1) = Array1(aCount).TagString
           Next aCount
           RowNum = 2
        End If
        'Puts Information Under Titles (i.e 100 Street, Town)
           anExcelActiveSheet.Cells(RowNum, aCount + 1) = Array1(aCount).TextString
           anExcelActiveSheet.Columns(aCount + 1).EntireColumn.AutoFit
           objXL.Cells(RowNum, 16) = CStr(cLay.Name)
           objXL.Cells(RowNum, 17) = DrgNo
        Next aCount
        RowNum = RowNum + 1
        DrgNo = DrgNo + 1
     Next elem
     ' Taking custom properties
      Cust = GetCurrentCustoms()
      For row = 0 To UBound(Cust, 1)
          objXL.Cells(row + 2, 21) = Cust(row, 0)
          objXL.Cells(row + 2, 22) = Cust(row, 1)
      Next
  'Job Number
          objXL.Range("P2:P21").NumberFormat = "00"
          objXL.Sheets("Sheet1").Name = "Job Data"
  'Drawing Titles (Max 60 i.e Max 3 Sheets)
          objXL.Columns("R:R").ColumnWidth = 100
          objXL.Range("R2").Formula = "=IF(ISBLANK(D2),"" "",IF(ISBLANK(H2),D2,CONCATENATE(D2,"" "",E2,"" "",F2)))"
          objXL.Range("R3").Formula = "=IF(ISBLANK(D3),"" "",IF(ISBLANK(H3),D3,CONCATENATE(D3,"" "",E3,"" "",F3)))"
          objXL.Range("R4").Formula = "=IF(ISBLANK(D4),"" "",IF(ISBLANK(H4),D4,CONCATENATE(D4,"" "",E4,"" "",F4)))"
          objXL.Range("R5").Formula = "=IF(ISBLANK(D5),"" "",IF(ISBLANK(H5),D5,CONCATENATE(D5,"" "",E5,"" "",F5)))"
          objXL.Range("R6").Formula = "=IF(ISBLANK(D6),"" "",IF(ISBLANK(H6),D6,CONCATENATE(D6,"" "",E6,"" "",F6)))"
          objXL.Range("R7").Formula = "=IF(ISBLANK(D7),"" "",IF(ISBLANK(H7),D7,CONCATENATE(D7,"" "",E7,"" "",F7)))"
          objXL.Range("R8").Formula = "=IF(ISBLANK(D8),"" "",IF(ISBLANK(H8),D8,CONCATENATE(D8,"" "",E8,"" "",F8)))"
          objXL.Range("R9").Formula = "=IF(ISBLANK(D9),"" "",IF(ISBLANK(H9),D9,CONCATENATE(D9,"" "",E9,"" "",F9)))"
          objXL.Range("R10").Formula = "=IF(ISBLANK(D10),"" "",IF(ISBLANK(H10),D10,CONCATENATE(D10,"" "",E10,"" "",F10)))"
          objXL.Range("R11").Formula = "=IF(ISBLANK(D11),"" "",IF(ISBLANK(H11),D11,CONCATENATE(D11,"" "",E11,"" "",F11)))"
          objXL.Range("R12").Formula = "=IF(ISBLANK(D12),"" "",IF(ISBLANK(H12),D12,CONCATENATE(D12,"" "",E12,"" "",F12)))"
          objXL.Range("R13").Formula = "=IF(ISBLANK(D13),"" "",IF(ISBLANK(H13),D13,CONCATENATE(D13,"" "",E13,"" "",F13)))"
          objXL.Range("R14").Formula = "=IF(ISBLANK(D14),"" "",IF(ISBLANK(H14),D14,CONCATENATE(D14,"" "",E14,"" "",F14)))"
          objXL.Range("R15").Formula = "=IF(ISBLANK(D15),"" "",IF(ISBLANK(H15),D15,CONCATENATE(D15,"" "",E15,"" "",F15)))"
          objXL.Range("R16").Formula = "=IF(ISBLANK(D16),"" "",IF(ISBLANK(H16),D16,CONCATENATE(D16,"" "",E16,"" "",F16)))"
          objXL.Range("R17").Formula = "=IF(ISBLANK(D17),"" "",IF(ISBLANK(H17),D17,CONCATENATE(D17,"" "",E17,"" "",F17)))"
          objXL.Range("R18").Formula = "=IF(ISBLANK(D18),"" "",IF(ISBLANK(H18),D18,CONCATENATE(D18,"" "",E18,"" "",F18)))"
          objXL.Range("R19").Formula = "=IF(ISBLANK(D19),"" "",IF(ISBLANK(H19),D19,CONCATENATE(D19,"" "",E19,"" "",F19)))"
          objXL.Range("R20").Formula = "=IF(ISBLANK(D20),"" "",IF(ISBLANK(H20),D20,CONCATENATE(D20,"" "",E20,"" "",F20)))"
          objXL.Range("R21").Formula = "=IF(ISBLANK(D21),"" "",IF(ISBLANK(H21),D21,CONCATENATE(D21,"" "",E21,"" "",F21)))"
          objXL.Range("R22").Formula = "=IF(ISBLANK(D22),"" "",IF(ISBLANK(H22),D22,CONCATENATE(D22,"" "",E22,"" "",F22)))"
          objXL.Range("R23").Formula = "=IF(ISBLANK(D23),"" "",IF(ISBLANK(H23),D23,CONCATENATE(D23,"" "",E23,"" "",F23)))"
          objXL.Range("R24").Formula = "=IF(ISBLANK(D24),"" "",IF(ISBLANK(H24),D24,CONCATENATE(D24,"" "",E24,"" "",F24)))"
          objXL.Range("R25").Formula = "=IF(ISBLANK(D25),"" "",IF(ISBLANK(H25),D25,CONCATENATE(D25,"" "",E25,"" "",F25)))"
          objXL.Range("R26").Formula = "=IF(ISBLANK(D26),"" "",IF(ISBLANK(H26),D26,CONCATENATE(D26,"" "",E26,"" "",F26)))"
          objXL.Range("R27").Formula = "=IF(ISBLANK(D27),"" "",IF(ISBLANK(H27),D27,CONCATENATE(D27,"" "",E27,"" "",F27)))"
          objXL.Range("R28").Formula = "=IF(ISBLANK(D28),"" "",IF(ISBLANK(H28),D28,CONCATENATE(D28,"" "",E28,"" "",F28)))"
          objXL.Range("R29").Formula = "=IF(ISBLANK(D29),"" "",IF(ISBLANK(H29),D29,CONCATENATE(D29,"" "",E29,"" "",F29)))"
          objXL.Range("R30").Formula = "=IF(ISBLANK(D30),"" "",IF(ISBLANK(H30),D30,CONCATENATE(D30,"" "",E30,"" "",F30)))"
          objXL.Range("R31").Formula = "=IF(ISBLANK(D31),"" "",IF(ISBLANK(H31),D31,CONCATENATE(D31,"" "",E31,"" "",F31)))"
          objXL.Range("R32").Formula = "=IF(ISBLANK(D32),"" "",IF(ISBLANK(H32),D32,CONCATENATE(D32,"" "",E32,"" "",F32)))"
          objXL.Range("R33").Formula = "=IF(ISBLANK(D33),"" "",IF(ISBLANK(H33),D33,CONCATENATE(D33,"" "",E33,"" "",F33)))"
          objXL.Range("R34").Formula = "=IF(ISBLANK(D34),"" "",IF(ISBLANK(H34),D34,CONCATENATE(D34,"" "",E34,"" "",F34)))"
          objXL.Range("R35").Formula = "=IF(ISBLANK(D35),"" "",IF(ISBLANK(H35),D35,CONCATENATE(D35,"" "",E35,"" "",F35)))"
          objXL.Range("R36").Formula = "=IF(ISBLANK(D36),"" "",IF(ISBLANK(H36),D36,CONCATENATE(D36,"" "",E36,"" "",F36)))"
          objXL.Range("R37").Formula = "=IF(ISBLANK(D37),"" "",IF(ISBLANK(H37),D37,CONCATENATE(D37,"" "",E37,"" "",F37)))"
          objXL.Range("R38").Formula = "=IF(ISBLANK(D38),"" "",IF(ISBLANK(H38),D38,CONCATENATE(D38,"" "",E38,"" "",F38)))"
          objXL.Range("R39").Formula = "=IF(ISBLANK(D39),"" "",IF(ISBLANK(H39),D39,CONCATENATE(D39,"" "",E39,"" "",F39)))"
          objXL.Range("R40").Formula = "=IF(ISBLANK(D40),"" "",IF(ISBLANK(H40),D40,CONCATENATE(D40,"" "",E40,"" "",F40)))"
          objXL.Range("R41").Formula = "=IF(ISBLANK(D41),"" "",IF(ISBLANK(H41),D41,CONCATENATE(D41,"" "",E41,"" "",F41)))"
          objXL.Range("R42").Formula = "=IF(ISBLANK(D42),"" "",IF(ISBLANK(H42),D42,CONCATENATE(D42,"" "",E42,"" "",F42)))"
          objXL.Range("R43").Formula = "=IF(ISBLANK(D43),"" "",IF(ISBLANK(H43),D43,CONCATENATE(D43,"" "",E43,"" "",F43)))"
          objXL.Range("R44").Formula = "=IF(ISBLANK(D44),"" "",IF(ISBLANK(H44),D44,CONCATENATE(D44,"" "",E44,"" "",F44)))"
          objXL.Range("R45").Formula = "=IF(ISBLANK(D45),"" "",IF(ISBLANK(H45),D45,CONCATENATE(D45,"" "",E45,"" "",F45)))"
          objXL.Range("R46").Formula = "=IF(ISBLANK(D46),"" "",IF(ISBLANK(H46),D46,CONCATENATE(D46,"" "",E46,"" "",F46)))"
          objXL.Range("R47").Formula = "=IF(ISBLANK(D47),"" "",IF(ISBLANK(H47),D47,CONCATENATE(D47,"" "",E47,"" "",F47)))"
          objXL.Range("R48").Formula = "=IF(ISBLANK(D48),"" "",IF(ISBLANK(H48),D48,CONCATENATE(D48,"" "",E48,"" "",F48)))"
          objXL.Range("R49").Formula = "=IF(ISBLANK(D49),"" "",IF(ISBLANK(H49),D49,CONCATENATE(D49,"" "",E49,"" "",F49)))"
          objXL.Range("R50").Formula = "=IF(ISBLANK(D50),"" "",IF(ISBLANK(H50),D50,CONCATENATE(D50,"" "",E50,"" "",F50)))"
          objXL.Range("R51").Formula = "=IF(ISBLANK(D51),"" "",IF(ISBLANK(H51),D51,CONCATENATE(D51,"" "",E51,"" "",F51)))"
          objXL.Range("R52").Formula = "=IF(ISBLANK(D52),"" "",IF(ISBLANK(H52),D52,CONCATENATE(D52,"" "",E52,"" "",F52)))"
          objXL.Range("R53").Formula = "=IF(ISBLANK(D53),"" "",IF(ISBLANK(H53),D53,CONCATENATE(D53,"" "",E53,"" "",F53)))"
          objXL.Range("R54").Formula = "=IF(ISBLANK(D54),"" "",IF(ISBLANK(H54),D54,CONCATENATE(D54,"" "",E54,"" "",F54)))"
          objXL.Range("R55").Formula = "=IF(ISBLANK(D55),"" "",IF(ISBLANK(H55),D55,CONCATENATE(D55,"" "",E55,"" "",F55)))"
          objXL.Range("R56").Formula = "=IF(ISBLANK(D56),"" "",IF(ISBLANK(H56),D56,CONCATENATE(D56,"" "",E56,"" "",F56)))"
          objXL.Range("R57").Formula = "=IF(ISBLANK(D57),"" "",IF(ISBLANK(H57),D57,CONCATENATE(D57,"" "",E57,"" "",F57)))"
          objXL.Range("R58").Formula = "=IF(ISBLANK(D58),"" "",IF(ISBLANK(H58),D58,CONCATENATE(D58,"" "",E58,"" "",F58)))"
          objXL.Range("R59").Formula = "=IF(ISBLANK(D59),"" "",IF(ISBLANK(H59),D59,CONCATENATE(D59,"" "",E59,"" "",F59)))"
          objXL.Range("R60").Formula = "=IF(ISBLANK(D60),"" "",IF(ISBLANK(H60),D60,CONCATENATE(D60,"" "",E60,"" "",F60)))"
          objXL.Range("R61").Formula = "=IF(ISBLANK(D61),"" "",IF(ISBLANK(H61),D61,CONCATENATE(D61,"" "",E61,"" "",F61)))"
           objXL.UserControl = True
      objXL.Application.ScreenUpdating = True 'Needs to Be Last Entry
  End If
End Sub
Function IsExcelRunning() As Boolean
On Error Resume Next
  Set objXL = GetObject(, "Excel.Application")
  If Err <> 0 Then
     Err.Clear
     Set objXL = CreateObject("Excel.Application")
     If Err <> 0 Then
        Err.Clear
        IsExcelRunning = False
        Exit Function
     End If
  End If
  IsExcelRunning = True
End Function
Function GetCurrentCustoms() As Variant
   Dim Num As Long
   Dim Index As Long
   Dim CustomKey As String
   Dim CustomValue As String
   Dim Sum As AcadSummaryInfo
   Set Sum = ThisDrawing.SummaryInfo
   Dim Cnt As Long
   Num = Sum.NumCustomInfo
   ReDim Cust(0 To Num - 1, 0 To 1) As String
   For Index = 0 To Num - 1
       Sum.GetCustomByIndex Index, CustomKey, CustomValue
       Cust(Cnt, 0) = CustomKey
       Cust(Cnt, 1) = CustomValue
       Cnt = Cnt + 1
   Next Index
   Set Sum = Nothing
   GetCurrentCustoms = Cust
   End Function
   Sub SSClear()
Dim SSS As AcadSelectionSets
  Set SSS = ThisDrawing.SelectionSets
     If SSS.Count > 0 Then
        SSS.Item("TempSSet").Delete
     End If
End Sub
Function AllSS(Optional grpCode As Variant, Optional dataVal As Variant) As Integer
  Dim TempObjSS As AcadSelectionSet
  SSClear
  Set TempObjSS = ThisDrawing.SelectionSets.Add("TempSSet")
        'pick selection set
  If IsMissing(grpCode) Then
     TempObjSS.Select acSelectionSetAll
  Else
     TempObjSS.Select acSelectionSetAll, , , grpCode, dataVal
  End If
  AllSS = TempObjSS.Count
End Function
You're a star.
Have altered the output to list as before.
Unfortunately I have one more problem.
Although most blocks are called "*Partners"
How do I add another to include "A4Sketch"
Regards
Streng
I'm not in a position to test it but believe:
intCode(1) = 2: varData(1) = "*Partners,A4Sketch"
should do.
