Fedge Posted July 25, 2005 Posted July 25, 2005 For the life of me I cannot figure out how to set up all LTSCALE/PSLTSCALE/CELTSCALE to suit my needs. I have a bunch of lines in my drawing that are set to the HIDDEN linetype. In model space, they show up as a continuous line. In paperspace, they show up dashed. Using LTSCALE, I tweaked the scale of the lines in PAPER space, but couldn't get those changes to effect model space. How can I see the same scale in both MS and PS? Is that possible? Another problem is that some of my viewports display the hidden lines in one scale, and others in another scale, and others yet don't display as hidden at all. What am I doing wrong? If someone would be kind enough to brief me on how to set up all of the LTSCALE's and whatnot, it would be MUCH appreciated. Thank you. Quote
Paul Sweet Posted July 26, 2005 Posted July 26, 2005 This was just discussed a week or so ago: http://www.cadtutor.net/forum/viewtopic.php?t=3683 Quote
Fedge Posted July 26, 2005 Author Posted July 26, 2005 I've read that thread over several times and unfortunately it doesn't answer some of my questions like the differences between model space and paper space, and why the linetype scales do no match. Some of the techniques discussed in the thread didn't work or produced un-desireable results. Is there any other resources I may be missing? Thanks. Quote
f700es Posted July 27, 2005 Posted July 27, 2005 I've read that thread over several times and unfortunately it doesn't answer some of my questions like the differences between model space and paper space, and why the linetype scales do no match. Some of the techniques discussed in the thread didn't work or produced un-desireable results. Is there any other resources I may be missing? Thanks. Set your PSLTSCALE to "0" and they will match. Quote
caddiva Posted November 30, 2008 Posted November 30, 2008 So, Fedge...did you get it to work? I am having the same problem and the link to the "specific forum" showed above was not working either... Quote
rkent Posted December 1, 2008 Posted December 1, 2008 For the life of me I cannot figure out how to set up all LTSCALE/PSLTSCALE/CELTSCALE to suit my needs. I have a bunch of lines in my drawing that are set to the HIDDEN linetype. In model space, they show up as a continuous line. In paperspace, they show up dashed. Using LTSCALE, I tweaked the scale of the lines in PAPER space, but couldn't get those changes to effect model space. How can I see the same scale in both MS and PS? Is that possible? Another problem is that some of my viewports display the hidden lines in one scale, and others in another scale, and others yet don't display as hidden at all. What am I doing wrong? If someone would be kind enough to brief me on how to set up all of the LTSCALE's and whatnot, it would be MUCH appreciated. Thank you. You don't say which version of AutoCAD you are using, so prior to v2009 the following will be the best place to start. Set PSTLSCALE to 1. In Model Space set LTSCALE to the intended plot scale. I.E.: plot scale to be 1/4"=1'-0", then while in MS set LTSCALE to 48. When you move to PS set LTSCALE to 1 or 0.5, you may have to hit regen. Leave CELTSCALE set to 1, if you need to adjust some individual lines then click on them, go to properties and adjust the linetype scale there. This is adjusting the CELTSCALE for those lines only. This shouldn't be used very often, IMO. With 2009 Annotative scaling was introduced so a new variable, MSLTSCALE, controls the above for you in a more automated manner. Set MSLTSCALE to 1 and the annotative scaling handles the rest. Quote
Tiger Posted December 1, 2008 Posted December 1, 2008 The date on this thread is 2005 - so not likely Fedge will be back to explain If RKents suggestions doesn't work Caddiva, I suggest you start a new thread with your question. Quote
soleary Posted December 1, 2008 Posted December 1, 2008 The date on this thread is 2005 - so not likely Fedge will be back to explain If RKents suggestions doesn't work Caddiva, I suggest you start a new thread with your question. Very observant Tiger Quote
Tiger Posted December 1, 2008 Posted December 1, 2008 Very observant Tiger Like I said to a collegue today, the only reason I know these things is because I have had the same problem before Quote
rovelom Posted November 15, 2011 Posted November 15, 2011 Set your PSLTSCALE to "0" and they will match. f700es you got the exact answer. Keep helping. Thanks Quote
