TheNewGuy Posted May 18, 2009 Share Posted May 18, 2009 Ok it is Monday morning and I have another question. I am noticing that the default text style in the standard acad.dwt template in 2009 is not going to work for me, as well as the dimension style. So how do I create a custom template that saves all those settings for me. So that when I start a new drawing I can select my template that I created and all those customizations that I have made will be brought up automaticly. I have searched the help file a little but I don't find the 2009 help file as helpfull as 2002. So... anyone want to help me...it would be greatly appriciated! Quote Link to comment Share on other sites More sharing options...
tzframpton Posted May 18, 2009 Share Posted May 18, 2009 Ok it is Monday morning and I have another question. I am noticing that the default text style in the standard acad.dwt template in 2009 is not going to work for me, as well as the dimension style. So how do I create a custom template that saves all those settings for me. So that when I start a new drawing I can select my template that I created and all those customizations that I have made will be brought up automaticly. I have searched the help file a little but I don't find the 2009 help file as helpfull as 2002. So... anyone want to help me...it would be greatly appriciated! Open a new drawing. Add the Text Styles, Dimension Styles, and anything else you want to have available when you open this particular drawing. When it is the way you want it, do a Save As > AutoCAD Template (*.dwt) file. Everytime you open this drawing it will be there. Oh and for better access, type STARTUP and change it to 1. Then go to Options > Files tab > Template Settings > Drawing Template File Location and put the path in where you will save all your own custom templates. That way every time you open AutoCAD or start a new drawing it will be easily accessable. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 18, 2009 Share Posted May 18, 2009 I have moved your question to it's own thread. In the future, please start a new thread when you have a new question. Quote Link to comment Share on other sites More sharing options...
TheNewGuy Posted May 18, 2009 Author Share Posted May 18, 2009 Thank you for your quick reply. I did as you said and It worked like a charm. Thanks again for all your help. Quote Link to comment Share on other sites More sharing options...
ian25 Posted October 31, 2009 Share Posted October 31, 2009 pls help me i want to know were can i find the libraries of standard drawing templates here in cad tutor Quote Link to comment Share on other sites More sharing options...
