This lisp for coordinate
click in the points in order then create a table with the points number and X&Y
when run the routen
its pick the points and insert the point number
But can not create the table
I hope to find a solution or a lisp same like
(defun derr (s)                       ; If an error (such as CTRL-C) occurs
                                     ; while this command is active...
 (if (/= s "Function cancelled")
   (princ (strcat "\n*Error: " s))
 (setvar "cmdecho" echo)
 (setvar "blipmode" blip)
 (setvar "luprec" decimal)
 (setq *error* olderr)               ; Restore old *error* handler
 (close file)
(defun c:pt()
  (setq olderr *error*
               *error* derr)
  (setq echo (getvar "cmdecho"))
  (setq blip (getvar "blipmode"))
  (setq decimal (getvar "luprec"))
  (setvar "cmdecho" 0)
  (setvar "blipmode" 0)
     (setq pt_file (getstring "\nPoints File Name <points.txt>:"))
     (if (= pt_file "")
         (setq file (open "points.txt" "w"))
         (setq file (open pt_file "w"))
     (setq h-scale (getint "\nHorizontal Scale  1:"))
     (setq pre_code (getstring "\nPrefix Code:"))
     (setq start_pn (getint "\nStart Number:"))
     (setq pn  start_pn)
     (setq hs-factor (/ h-scale 100))
     (setq p 0)
     (setq n 1)
     (while p
            (setq p (getpoint "\nSelect Point <Exit>:"))
            (if p
                   (setq str_pn (itoa pn))
                   (setq pt_code (strcat pre_code str_pn))
                   (setq ptxt (list
                                 (- (car p) (* 0.5 hs-factor))
                                 (+ (cadr p) (* 0.5 hs-factor))
                   (command "point" p)
                   (command "text" "m" ptxt "0" pt_code)
                   ;Writting Selected point to the file
                   (princ (strcat "\n" pt_code " " (rtos (car p)) " "
                                  (rtos (cadr p)) ) file)
                   (setq pn (+ pn 1))
                   (setq pt_list1 (list (append (list pt_code) p)))
                   (if (= n 1)
                       (setq pt_list pt_list1)
                       (setq pt_list (append pt_list pt_list1))
                   (setq n (+ n 1))
  (prompt "\n** Points Coordinates Table **")
  (setq p_l_up (getpoint "\nSelect Upper Left Cornner :\n"))
  (setq p_r_up (list (+ (car p_l_up) (* 7.2 hs-factor))
                     (cadr p_l_up) ))
  (setq ph1 (list (car P_l_up)
                  (- (cadr p_l_up) (* 1 hs-factor)) ))
  (setq ph2 (list (car P_r_up)
                  (- (cadr p_r_up) (* 1 hs-factor)) ))
  (setq ph_txt1 (list (+ (car p_l_up) (* 0.6 hs-factor))
                      (- (cadr p_l_up) (* 0.5 hs-factor)) ))
  (setq ph_txt2 (list (+ (car p_l_up) (* 2.7 hs-factor))
  (setq ph_txt3 (list (+ (car p_l_up) (* 5.7 hs-factor))
  (command "line" p_l_up p_r_up "")
  (command "line" ph1 ph2 "")
  (command "text" "m" ph_txt1 "0" "Pt.")
  (command "text" "m" ph_txt2 "0" "X")
  (command "text" "m" ph_txt3 "0" "Y")
  (setq len_ptlst (length pt_list))
  (setq n_lst 0)
  (repeat len_ptlst
             (setq p1 (list (car ph1)
                            (- (cadr ph1) (* 1 (+ n_lst 1) hs-factor)) ))
             (setq p2 (list (car ph2)
                            (- (cadr ph2) (* 1 (+ n_lst 1) hs-factor)) ))
             (setq ptxt1 (list
                           (car ph_txt1)
                           (- (cadr ph_txt1)(* 1 (+ n_lst 1) hs-factor)) ))
             (setq ptxt2 (list
                           (car ph_txt2)
                           (- (cadr ph_txt2)(* 1 (+ n_lst 1) hs-factor)) ))
             (setq ptxt3 (list
                           (car ph_txt3)
                           (- (cadr ph_txt3)(* 1 (+ n_lst 1) hs-factor)) ))
             (setq x (rtos (nth 1 (nth n_lst pt_list))))
             (setq y (rtos (nth 2 (nth n_lst pt_list))))
             (princ (strcat "\rPoint Number " (nth 0 (nth n_lst pt_list))))
             (command "text" "m" ptxt1 "0" (nth 0 (nth n_lst pt_list)))
             (command "text" "m" ptxt2 "0" x)
             (command "text" "m" ptxt3 "0" y)
             (command "line" p1 p2 "")
          (setq n_lst (+ n_lst 1))
  (setq pv1 (list (+ (car p_l_up) (* 1.2 hs-factor))
                  (cadr p_l_up) ))
  (setq pv2 (list (+ (car p_l_up) (* 4.2 hs-factor))
                  (cadr p_l_up) ))
  (setq pv3 (list (+ (car p1) (* 1.2 hs-factor))
                  (cadr p1) ))
  (setq pv4 (list (+ (car p1) (* 4.2 hs-factor))
                  (cadr p1) ))
  (command "line" p_l_up p1 "")
  (command "line" pv1 pv3 "")
  (command "line" pv2 pv4 "")
  (command "line" p_r_up p2 "")
  (close file)
In fact I have no experiance in lisp
How can I use that objects?
