using lisp does anyone know how to search all folders in a drive for .dwl files??
Something like this maybe?
(defun fSearch (dir ext)
 (vl-load-com)
 (if (vl-file-directory-p dir)
   (vl-directory-files dir (strcat "*." ext))))
Lee Mac - Thank you
That works when you specify the specific directory.
But does anyone know if it is possible to search all directories within a Drive say "C:" ??
I was thinking something like this (inspiration from Jeff Mishler):
(defun fSearch (Dir Ext Subf / files Subs)
 (vl-load-com)
 (if (vl-file-directory-p Dir)
     (setq files (vl-directory-files Dir (strcat "*." Ext)))
     (if (and Subf
           (setq Subs (vl-directory-files Dir "*" -1)
                 Subs (vl-remove "."  Subs)
                 Subs (vl-remove ".." Subs)))
       (foreach Sub Subs
         (fSearch (strcat Dir Sub) Ext Subf)))
     (if files
       (setq *files* (append *files* files))))))
(defun c:test (/ *files*)
 (setq *files* '())
 (fSearch "C:\\" "dwl" T)
 (alert (vl-princ-to-string *files*)))
I see where you are going with that - its a great start - i'll have a look at it and try to work it out - at the moment it is returning nil.
Does it work at your end??
Just tested - it returns nil my end too :(
Will look into it :)
This may help you:
http://www.theswamp.org/index.php?topic=8427.0
Lee mac this works and cycles through folders.
You could search for any type of file.
It works slow with using an entire drive.
I need to set up something so i can see what drawings are currently opened.
 (setq *files* '())
;(alert (strcat "Directory = " dir))
 (vl-load-com)
(if (and Subf
           (setq Subs (vl-directory-files Dir nil -1)
       (foreach itm Subs
         (fSearch (strcat Dir "\\" itm) Ext Subf)))
     (if files
       (setq *files* (append *files* files ))))))
i was using these two snippets of code that i think Asmi helped me with ages ago.The code is loaded automatically on everyones acad in this office.
But i just need to work out how to compare the spreadsheets to see what drawings are still open and by what user.
It just makes things a lot easier to manage when you have such a large design and drafting team.
If you know of any way to create a list of what drawings are currently open by which user would you please let me know.
Cheers
;ON OPEN
(defun-q S::STARTUP (/ Draftername Job file line2write)
(setq p1 (strcat (menucmd "M=$(edtime,$(getvar,date),MON - DDD D YY )")))
(setq Draftername (getvar "loginname"))
(setq Job (strcat (getvar "dwgprefix") (getvar "dwgname")))
 (setq LogOpendatefile (open (strcat "R:\\Temp\\Russell\\DWGLOG\\" p1 "CADCivilDrawingLog.csv") "a"))
 (setq line2write (strcat
        Draftername
        (menucmd "M=$(edtime,$(getvar,date),HH:MM AM/PM)")
      "Opened"
 Job))
 (write-line line2write LogOpendatefile)
 (close LogOpendatefile)
(Setq dwglogopen (open "R:\\Temp\\Russell\\DWGLOG\\~CADCivilOpenDwgsOverall.csv" "a"))
 (setq line2writeOverall (strcat
        Draftername
        (menucmd "M=$(edtime,$(getvar,date),MON D YY HH:MM AM/PM)")
        "Closed"
 Job))
(write-line line2writeOverall dwglogopen)
(close dwglogopen)
(setq userfile (open (strcat "C:\\" p1 "AutocadCivilUserDrawingLog.csv") "a"))
(write-line line2write userfile)
(close userfile)
(princ))
;ON CLOSE
(defun Create_Close_Reactor()
 (vl-load-com)
 (if(not close:reactor)
   (setq close:reactor
  (vlr-editor-reactor nil
    '((:vlr-beginClose . CloseReaction))))
   ); end if
 ); end of Create_Close_Reactor
(defun CloseReaction(args reac / actDoc)
 (setq LogCloseddatefile (open (strcat "R:\\Temp\\Russell\\DWGLOG\\" p1 "CADCivilDrawingLog.csv") "a"))
        Draftername
        "Closed"
 Job))
 (write-line line2write LogCloseddatefile)
 (close LogCloseddatefile)
(Setq dwglogClosed (open "R:\\Temp\\Russell\\DWGLOG\\~CADCivilClosedDwgsOverall.csv" "a"))
        Draftername
        "Closed"
 Job))
(write-line line2writeOverall dwglogClosed)
(close dwglogClosed)
(close userfile)
 ); end of CloseReaction
(Create_Close_Reactor)
