Hi,
I'm tring to make a VBA code to clear a layers content.
So far i the code below but it is deleting everything from all layers..
Anyone got a sugestion?
Cheers Jeroen
Sub ClearLayer()
Dim SSet As AcadSelectionSet
Dim test2 As String
On Error Resume Next
Set SSet = ThisDrawing.SelectionSets.Add("test2")
SSet.Select acSelectionSetAll
SSet.Erase
SSet.Delete
End Sub
What do you mean deleting everything from all layers?
Do you mean erasing the drawing or resetting the properties?
If it is erasing the drawing, then try the "New" command. If it is resetting the properties, then just change the properties to what you want.
Could you be any clearer?
Thanks.
The code not only deletes all lines and text from the layer "test2" but also from all othere layers. I'm want the code only to delete al lines and text from the layer "test2".
A selection set has to be set up to only accept entities on a particular layer.
Sub ClearLayerWithFilter()
Dim intCode(1) As Integer
Dim varData(1) As Variant
intCode(0) = 8: varData(0) = "test2" 'only select items on layer "test2"
intCode(1) = 67: varData(1) = 0 'only select items in modelspace - error without this filter
ThisDrawing.SelectionSets.Item("test2").Delete
On Error GoTo 0
SSet.Select acSelectionSetAll, , , intCode, varData
SSet.Erase
End Sub
Is the intent to collect all entities of a particular layer in both model- and paperspace? If so, then a different tack may need to be employed. With selection sets, an error is thrown when dealing with both model and paperspace. The second routine does its own iteration to eliminate entities in the entire drawing.
Sub ClearLayerWithIteration()
Dim objDataBase As AcadDatabase
Dim objBlock As AcadBlock
Dim ent As AcadEntity
Dim count As Integer
Dim i As Integer
Dim entCollection As Collection
Dim varHandle As Variant
Set entCollection = New Collection
For Each objBlock In ThisDrawing.Blocks
  count = objBlock.count
  For i = 0 To count - 1
     If TypeOf objBlock.Item(i) Is AcadEntity Then
        If objBlock.Item(i).Layer = "test2" Then entCollection.Add (objBlock.Item(i).Handle)
     End If
  Next
  For Each varHandle In entCollection
     Set ent = ThisDrawing.HandleToObject(CStr(varHandle))
     ent.Delete
  Next
  On Error GoTo 0
Next
End Sub
