T2L Posted July 22, 2009 Posted July 22, 2009 How can I make it transferable or make it attach or be part of the drawing? Here is what I did: I created the said variable using lisp in my acaddoc file and then I made a text using FIELD to access the variable using diesel expression but when I send the drawing to another station it did not show, it show a dash line only. Any thought or solution? T2L Btw, I used (setenv) to create the custom variable. Quote
Lee Mac Posted July 22, 2009 Posted July 22, 2009 If you are using setenv then the variable is written to the registry, and will need to be retrieved with getenv. Other ways include using vl-propagate, or vl-bb-set and using the blackboard namespace. Quote
T2L Posted July 22, 2009 Author Posted July 22, 2009 If you are using setenv then the variable is written to the registry, and will need to be retrieved with getenv. Other ways include using vl-propagate, or vl-bb-set and using the blackboard namespace. Yes, I've used (getenv) to retrieved it. However my question remain, How do I keep it permanently in the drawing when I send the drawing to another station. As you said setenv write it to registry (of the originator's station) and it will stay there permanently but it will not be on another station unless you tell them to re-create it. Quote
Lee Mac Posted July 22, 2009 Posted July 22, 2009 How about storing it somewhere in the drawing like in xdata or ldata in objects.. draiwng a blank here Try over at theSwamp.org, you may get more success if we can't help Lee Quote
Se7en Posted July 22, 2009 Posted July 22, 2009 I'm thinking here: A persistent reactor would maybe work. Quote
