I am wondering how to make a coil on auto cad 2008. From what I can figure out is to extrude a circle or ellipse using a helix for the path. So far all I have gotten is a spiraling ribbon. I believe the problem is aligning the z-axis with the end of the helix. can anyone help?
Try SWEEP. Sometimes it will give you better results.
KC
ah thanks, that works great. Though I figured out my method, Sweep shall now be one of my most used comands
Helix command. Explode the helix or spiral created then draw the circle @ the end and extrude or sweep using the helix or coil.
I would not recommend exploding the helix. There's no need to.
