How to add more than one testexpr to IF?
How can I add more than one testexpr to IF?
(if [testexpr1 AND testexpr2] progn1 (if [testexpr3 AND testexpr4] progn2 (if [testexpr5 AND testexpr6] progn3 progn4)))
for example
(Defun C:ColDim ()
(setq p1 (getpoint "\nPick Center point."))
(setq p2 (getpoint "\nPick Corner point."))
(if ( (cadr p1) (cadr p2)) condtn1
(if (
(if (> (car p1) (car p2)) and (
(if (> (car p1) (car p2)) and (> (cadr p1) (cadr p2)) condtn4
(defun condtn1 ()
(defun condtn2 ()
(defun condtn3 ()
(defun condtn4 ()
  • Replies 25
  • asos2000
    13
  • Lee Mac
    10
  • BearDyugin
    2
  • Tharwat
    1
Posted Images
Returns the logical AND of the supplied arguments
(and [expr ...])
Arguments
expr
Any expression.
Return Values
Nil, if any of the expressions evaluate to nil; otherwise T. If and is issued without arguments, it returns T.
(Defun C:ColDim ()
(if(and (< (car p1) (car p2))(> (cadr p1) (cadr p2))) condtn1
(if(and (< (car p1) (car p2))(< (cadr p1) (cadr p2))) condtn2
(if(and (> (car p1) (car p2))(< (cadr p1) (cadr p2))) condtn3
(if(and (> (car p1) (car p2))(> (cadr p1) (cadr p2))) condtn4
(defun condtn1 ()
(defun condtn2 ()
(defun condtn3 ()
(defun condtn4 ()
What I want is.
The user will pick the intersection point p1 then pick the corner to add the dimension p2, and the second point location will specify the direction of the dimension
(defun c:test2 ()
(setq txt (getstring "\n Column Number: "))
(setq p3 (list (max (car p1)(car p2))(max (cadr p1)(cadr p2))))
(setq p4 (list (min (car p1)(car p2))(max (cadr p1)(cadr p2))))
(setq p5 (list (min (car p1)(car p2))(min (cadr p1)(cadr p2))))
(setq p6 (list (- (min (car p3)(car p4)) 400)(+ 400 (max (cadr p4)(cadr p5)))))
(command "_.dimlinear" "_non" p3 "_non" p4 "_non" (polar p3 (/ pi 2.) 400) )
(command "_.dimlinear" "_non" p4 "_non" p5 "_non" (polar p5 pi 400) )
(entmakex (list (cons 0 "TEXT")
(cons 1 txt)
(cons 40 (getvar "textsize"))
(cons 10 p6)))
(if(and (
(cons 1 txt)
(cons 10 p6)))
(if(and (
(setq p4 (list (max (car p1)(car p2))(max (cadr p1)(cadr p2))))
(setq p5 (list (max (car p1)(car p2))(min (cadr p1)(cadr p2))))
(cons 1 txt)
(cons 10 p6)))
(cons 1 txt)
(cons 10 p6)))
I hope that to be in right direction
PS - The points not finalized yet
- This is second routine for me.
(defun c:test2 ()
 (setq p3 (list (car p2)(cadr p1)))
 (setq p4 (list (car p1)(cadr p2)))
 (setq p5 (polar p3 (angle p1 p3) 400))
 (setq p6 (polar p4 (angle p1 p4) 400))
 (setq p7 (polar p2 (angle p1 p2) 565.68542495))
(command "_.dimlinear" "_non" p2 "_non" p3 "_non" p5 )
(command "_.dimlinear" "_non" p2 "_non" p4 "_non" p6 )
(cons 1 txt)
(cons 10 p7)))
Why text - entmakex, but dimension - command?
Another method:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:test [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] *error* DIMOFF P1 P2 P3 P4 SPC TXT UFLAG[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] DimOff [b][color=#009999]400.0[/color][/b][b][color=RED])[/color][/b] [i][color=#990099];; Dimension Offset Distance[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] *error* [b][color=RED]([/color][/b]msg[b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] uFlag [b][color=RED]([/color][/b][b][color=BLUE]vla-EndUndoMark[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]wcmatch[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcase[/color][/b] msg[b][color=RED])[/color][/b] [b][color=#a52a2a]"*BREAK,*CANCEL*,*EXIT*"[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#a52a2a]"\n** Error: "[/color][/b] msg [b][color=#a52a2a]" **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] doc [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b]doc[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b]
                          [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-Acad-Object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       spc [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]zerop[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-activespace[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]=[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-mspace[/color][/b] doc[b][color=RED])[/color][/b] [b][color=Blue]:vlax-true[/color][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]vla-get-modelspace[/color][/b] doc[b][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]vla-get-paperspace[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]vla-get-modelspace[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] p1 [b][color=RED]([/color][/b][b][color=BLUE]getpoint[/color][/b] [b][color=#a52a2a]"\nPick Center Point: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] p2 [b][color=RED]([/color][/b][b][color=BLUE]getpoint[/color][/b] [b][color=#a52a2a]"\nPick Corner Point: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]/=[/color][/b] [b][color=#a52a2a]""[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] txt [b][color=RED]([/color][/b][b][color=BLUE]getstring[/color][/b] [b][color=#a52a2a]"\nColumn Number: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] uFlag [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-StartUndoMark[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]apply[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=Blue]vla-AddDimRotated[/color][color=RED])[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] spc[b][color=RED])[/color][/b]
                    [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b]
                      [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=Blue]vlax-3D-point[/color][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b]  p3 [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] p1[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] p2[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]caddr[/color][/b] p1[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] p2
                            [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] p3 [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] p1 p3[b][color=RED])[/color][/b] DimOff[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                    [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009999]0.[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] p2 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b]  p4 [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] p2[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] p1[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]caddr[/color][/b] p1[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                               [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] p4 [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] p1 p4[b][color=RED])[/color][/b] DimOff[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                    [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] [b][color=BLUE]pi[/color][/b] [b][color=#009999]2.[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]vla-AddText[/color][/b] spc txt
       [b][color=RED]([/color][/b][b][color=BLUE]vlax-3D-point[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] p2 [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] p1 p2[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]sqrt[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] [b][color=#009999]2.[/color][/b] DimOff Dimoff[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#a52a2a]"TEXTSIZE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] uFlag [b][color=RED]([/color][/b][b][color=BLUE]vla-EndUndoMark[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Thanks LEE
First of all I would like to thank you for this good lisp
Second I tired to seach in help about the VLA functions but not found but found in VBA section, So Could you explain some of this functions.
Thanks LEE
The explanation for the functions is written for VBA, so you just have to make the connection to Visual LISP. The arguments and their order are given :)
So you add VLA to convert to VBA
Not always - but the methods and properties are similar.
So
What is the usage of each part?
and Can I add this parts at the begining of each lisp?
(defun *error* (msg)
(and uFlag (vla-EndUndoMark doc))
(princ (strcat "\n** Error: " msg " **")))
(princ))
this part to deal with the error messages
but should not be StartUndoMark
(setq doc (cond (doc) ((vla-get-ActiveDocument
(vlax-get-Acad-Object))))
to create an object in autocad
spc (if (zerop (vla-get-activespace doc))
(if (= (vla-get-mspace doc) :vlax-true)
(vla-get-modelspace doc)
(vla-get-paperspace doc))
(vla-get-modelspace doc)))
Is this part to allow the object to be drawn in modelspace and papaerspace?
The vla-EndUndoMark completes the Undo pair, should the routine crash before EndUndomark is evaluated.
This part gets the Document object from the AutoCAD Application Object - see the Object model structure in the help.
This just gets the active space, whether it be Model, Paper or Model through a Viewport.
  • 1 month later...
I am trying to add a loop but not working, I dont know why
(defun c:test (/ *error* DIMOFF P1 P2 P3 P4 SPC TXT UFLAG)
(vl-load-com)
(setq DimOff (getreal "\n What is Drawing Scale? 1:"))
(princ))
(while
(if (and (setq p1 (getpoint "\nPick Axes Crossing Point: "))
(setq p2 (getpoint "\nPick Corner Point: "))
(setq uFlag (not (vla-StartUndoMark doc)))
(apply (function vla-AddDimRotated)
(append (list spc)
(mapcar
(function vlax-3D-point)
(list (setq p3 (list (car p1) (cadr p2) (caddr p1))) p2
(polar p3 (angle p1 p3) (* DimOff 8))))
'(0.)))
(append (list spc)
(mapcar
(list p2 (setq p4 (list (car p2) (cadr p1) (caddr p1)))
(polar p4 (angle p1 p4) (* DimOff 8))))
(list (/ pi 2.))))
(vla-AddText spc txt
(vlax-3D-point
(polar p2 (angle p1 p2) (sqrt (* 2. (* DimOff 8) (* DimOff 8))))) (getvar "TEXTSIZE"))
(setq uFlag (vla-EndUndoMark doc))))
In your code the whole IF statement will need to return T for it to loop, and you wouldn't be able to exit if it did.
Much easier:
 (vl-load-com)
 (setq DimOff 400.0) ;; Dimension Offset Distance
   (princ))
 (while (and (setq p1 (getpoint "\nPick Center Point: "))
             (/= "" (setq txt (getstring "\nColumn Number: "))))
            (append (list spc)
                    (mapcar
                            (polar p3 (angle p1 p3) DimOff)))
                    '(0.)))
            (append (list spc)
                    (mapcar
                               (polar p4 (angle p1 p4) DimOff)))
                    (list (/ pi 2.))))
       (vlax-3D-point
         (polar p2 (angle p1 p2) (sqrt (* 2. DimOff Dimoff)))) (getvar "TEXTSIZE"))
 (princ))
Could we delete colum no request
I added ; next to the line but the loop not working
Because it is part of the AND statement.
Should there be no Column text also then?
Lee
is it ok
(vl-load-com)
(princ))
;(/= "" (setq txt (getstring "\nColumn Number: ")))
(append (list spc)
(mapcar
'(0.)))
(append (list spc)
(mapcar
(list (/ pi 2.))))
;(vla-AddText spc txt
; (vlax-3D-point
; (polar p2 (angle p1 p2) (sqrt (* 2. DimOff Dimoff)))) (getvar "TEXTSIZE"))
(princ))
There is a question
How to post the lisp with the same format as lisp editor?
Asos,
Use
 tags instead of  tags to post code.
Read here:
http://www.cadtutor.net/forum/showthread.php?t=9184
To get the colours of the Visual LISP Editor, I wrote a LISP to read the LISP file and write out code with the colour added. :)
You should be change your name to Lisp MAc instead of Lee Mac
