Posted this over at the Swamp, thought I'd share it with you guys too.
The fractal images can be created using a set of iterated maps of the form:
Each being applied recursively, with varying probability.
(defun c:fern (/ ptlst pt probability)
 ;; Lee Mac  ~  20.02.10
 (repeat 50000
   (setq probability (rng))
   (Point (setq pt  (cond (  (< probability 0.01)
                             (iterate pt '((0.0 0.0)
                                           (0.0 0.16)) '(0.0 0.0)))
                          (  (<= 0.01 probability 0.86)
                             (iterate pt '(( 0.85 0.04)
                                           (-0.04 0.85)) '(0.0 1.6)))
                          (  (< 0.86 probability 0.93)
                             (iterate pt '((0.20 -0.26)
                                           (0.23  0.22)) '(0.0 1.6)))
                          (t (iterate pt '((-0.15 0.28)
                                           ( 0.26 0.24)) '(0.0 0.44)))))))
 (princ))
(defun c:sierpinski (/ ptlst pt probability)
 (repeat 50000
   (Point (setq pt (cond (  (< probability 0.333)
                            (iterate pt '((0.5 0.0)
                                          (0.0 0.5)) '(0.0 0.0)))
                         (  (<= 0.333 probability 0.666)
                                          (0.0 0.5)) '(0.5 0.0)))
                         (t (iterate pt '((0.5 0.0)
                                          (0.0 0.5)) '(0.25 0.5)))))))
 (princ))
(defun iterate (point matrix vector)
 (mapcar
   (function +)
     (mapcar
       (function
         (lambda (row)
           (apply (function +)
                  (mapcar (function *) row point)))) matrix) vector))
(defun rng (/ modulus multiplier increment random) ;; Stig
 (if (not seed) (setq seed (getvar "DATE")))
 (setq modulus    4294967296.0 multiplier 1664525 increment 1
       seed       (rem (+ (* multiplier seed) increment) modulus)
       random     (/ seed modulus)))
(defun Point (pt)
 (entmakex (list (cons 0 "POINT") (cons 10 pt) (cons 62 40))))
I have also created a small program so that you may easily generate these fractals, and many others, just using various 'Rules' representing each iterated mapping.
See what you can come up with!
If you have any questions about the processes involved, I'd be more than happy to explain. :)
Enjoy!,
Lee
Mapping.lsp
Lee: The last one almost looks like it could pass for ground cover in an architectural plan. Is there anyway to constrain it using a boundary of sorts?
Its just a collection of Points, and is not properly defined I suppose until n goes to infinity where n is the number of times the function has been recursively iterated:
f(f(...f(x)))  ~ n times
So, the boundary would always only be an approximation :)
