i have a lot of dlls in vb6 that work like a charm from autocad 2004 to autocad 2009
but now im having a lot of problems with AutoCAD 2010
schema of all VB6 dlls is
Initialize Class
Show a Form in vbModal (if i try to do it modeless then Form does not appear)
Press Run Command Button, hide form, send a prompt to autocad and try to make a selection on screen
but then AutoCAD is blocked, selection cursor appears on screen but i cant do anything and must terminate autocad from windows task manager
this problem does not happen when i make a selectonscreen from a vb6 dll with no forms
anyone knows what is happening with AutoCAD 2010? do not want to rewritte all code in NET
32-bit or 64-bit version?
We are talking VB 6.0 with Service Pack 5 right?
32 bits
VB6 SP6
something like this just block autocad 2010 in my computer
Test.zip
Just so I am clear on this, both AutoCAD 2010 and VB 6.0 are 32-bit right?
yes
it is so strange, cos it works nice while debugging dll, but not after compilling dll
i changed the code this way
Private Sub Command1_Click()
Dim objSelset As AcadSelectionSet
On Error GoTo ErrControl
Me.Hide
LimpiaDibu
Set xAcad = GetObject(, "AutoCAD.Application.18")
Set ThisDrawing = xAcad.ActiveDocument
Set objSelset = ThisDrawing.SelectionSets.Add("SS2")
objSelset.SelectOnScreen
MsgBox objSelset.Count
exithere:
Me.Show
On Error Resume Next
ThisDrawing.SelectionSets.Item("SS2").Delete: Set objSelset = Nothing
Err.Clear
Exit Sub
ErrControl:
MsgBox "Error en MenuTest. " & Err.Number & " (" & Err.Description & ") de " & Err.Source, vbCritical, "eRROR"
Err.Clear
Resume exithere
End Sub
i found the problem
i must place inside EVERY SUB
but in autocad2004 to 2009, i only need to place it on UserForm_Initialize()
just only one time
Well I'm glad you found a solution to your problem even though on the surface of it one would wonder why the code had to be tweaked to work in AutoCAD 2010. Thank you for sharing the solution with us and for updating us.
you're welcome
ill try to spent some time in this community
you're welcome
We certainly encourage everyone's involvement including yours. Thanks.
