ILoveMadoka Posted March 1, 2010 Posted March 1, 2010 I'm sure I will be embarrassed at how simple this is but I do not know how to write a simple routine to pick a single dimension and have the center mark setting changed to None. I have to do this often enough that I'd like to have a C:MO (Mark Off) command for this situation. 99% of the time I need the Center Mark on. I know I can pick it from the Properties Dialog. I just would like a routine for these instances. TIA!! Quote
nukecad Posted March 1, 2010 Posted March 1, 2010 Create a second dimstyle with no centre mark and use this when you need it? Quote
ILoveMadoka Posted March 1, 2010 Author Posted March 1, 2010 I was hoping for a quicky two letter command if at all possible... Quote
alanjt Posted March 1, 2010 Posted March 1, 2010 Would this work? Untested... (defun c:TEst (/ #SS) (cond ((setq #SS (ssget "_:L" '((0 . "DIMENSION")))) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*)) (vl-catch-all-apply 'vla-put-centertype (list x acCenterNone)) ) ;_ vlax-for (vl-catch-all-apply 'vla-delete (list #SS)) ) ) ;_ cond (princ) ) ;_ defun Quote
ILoveMadoka Posted March 1, 2010 Author Posted March 1, 2010 Works like a charm! Exactly what I was hoping for!! Thank you SO much!!! Quote
ILoveMadoka Posted March 1, 2010 Author Posted March 1, 2010 I know a tiny bit about lisp but nothing about VLA. Is is hard to code this in autolisp? (I was just wondering how hard it would have been to code it in simple lisp) (ie: How stupid am I really??!!) If it's too much of a hassle, don't bother (it's works fine) I'm just wondering from a "I'm trying to learn" standpoint.. thanks again either way! Quote
mdbdesign Posted March 1, 2010 Posted March 1, 2010 ^C^C_DIMCEN;0;^C^C_-dimstyle _apply \\^C^C_DIMCEN;0.09 Put this code into button, replace last #( in red) with your variable. I know I am late but it is simple to understand. Quote
