searching for subtracting lisp
ayman
  • Replies 20
  • Lee Mac
    7
  • ayman
    6
  • alanjt
    3
  • Shaheensha976
    3
Try this:
(defun c:subtxt (/ ParseNumbers GR NUM1 NUM2 P RES)
 (vl-load-com)
 ;; Lee Mac  ~  09.04.10
 (defun ParseNumbers (str / lst Num Aph x rtn)
   ;; Lee Mac  ~  20.09.09
   (setq lst (vl-string->list str) Num "" Aph "")
   (while (setq x (car lst))
     (setq lst (cdr lst))
     (cond (  (and (/= "" Num) (= 46 x))
              (setq Num (strcat Num (chr x))))
           (  (< 47 x 58)
                    rtn (cons Aph rtn) Aph ""))
           (t (setq Aph (strcat Aph (chr x))
                    rtn (cons (read Num) rtn) Num ""))))
   (vl-remove nil
     (vl-remove ""
       (reverse (cons Aph (cons (read Num) rtn))))))
 (mapcar
   (function
     (lambda (sym str / ent)
       (while
           (setq ent (car (nentsel str)))
           (cond (  (eq 'ENAME (type ent))
                    (if (wcmatch (cdr (assoc 0 (entget ent))) "*TEXT")
                      (if (not
                            (set sym
                              (car
                                (vl-remove-if-not
                                  (function
                                    (lambda (x)
                                      (vl-position
                                        (type x) '(INT REAL))))
                                  (ParseNumbers
                                    (cdr
                                      (assoc 1 (entget ent))))))))
                        (princ "\n** Text Must Contain a Number **"))
                      (princ "\n** Object Must be Text **")))
                 (  (princ "\n** Nothing Selected **")))))))
   '(num1 num2) '("\nSelect Text to Subtract from: " "\nSelect Text to Subtract: "))
 (if (and num1 num2
          (setq res (entmakex (list (cons 0 "TEXT")
                                    (cons 10  (getvar 'VIEWCTR))
                                    (cons 40  (getvar 'TEXTSIZE))
                                    (cons 7   (getvar 'TEXTSTYLE))
                                    (cons 1   (rtos (- num1 num2))))))
          (setq res (entget res)))
   (while (and (= 5 (car (setq gr (grread 't 13 0))))
                 (listp (setq p (cadr gr))))
       (entupd
         (cdr
           (assoc -1
             (setq res
               (entmod
                 (subst (cons 10 p) (assoc 10 res) res))))))))
 (princ))
lee mac thank you very much you are so kind that was wat i want but i want the result rotated at 90 degree and precision 2 like this 3.52 and make it multiple because i have too much number thanks again
Try this:
 (vl-load-com)
           (  (< 47 x 58)
   (vl-remove nil
     (vl-remove ""
 (mapcar
   (function
       (while
                      (if (not
                            (set sym
                              (car
                                (vl-remove-if-not
                                  (function
                                    (lambda (x)
                                      (vl-position
                                  (ParseNumbers
                                    (cdr
 (if (and num1 num2
                                    (cons 50  (/ pi 2))
                                    (cons 1   (rtos (- num1 num2) (getvar 'LUNITS) 2)))))
       (entupd
         (cdr
           (assoc -1
             (setq res
               (entmod
 (princ))
lee mac ther's small thing
i want when i call the lisp and when he ask me for selecting text to subtract from i want to select many number not just one
ant when i hit enter it ask me to select Text to Subtract ant when i hit enter it give me the result and this image will exlanin what i want
thank's lee for help
Nice one Alan :thumbsup:
I'll probably never use it (I haven't used the old one I have in a year or so), but it was fun to write.
lee mac firest of all thank's for help the secend is i have too much to click pair because i have too much pairs so if u do what i want it will be better and thank's for help man
Consider how much work you would have without what was provided to you, for free.
  • 6 months later...
  • 9 years later...
On 4/9/2010 at 3:25 PM, Lee Mac said:
(defun c:subtxt (/ ParseNumbers GR NUM1 NUM2 P RES) (vl-load-com) ;; Lee Mac ~ 09.04.10 (defun ParseNumbers (str / lst Num Aph x rtn) ;; Lee Mac ~ 20.09.09 (setq lst (vl-string->list str) Num "" Aph "") (while (setq x (car lst)) (setq lst (cdr lst)) (cond ( (and (/= "" Num) (= 46 x)) (setq Num (strcat Num (chr x)))) ( (< 47 x 58) (setq Num (strcat Num (chr x)) rtn (cons Aph rtn) Aph "")) (t (setq Aph (strcat Aph (chr x)) rtn (cons (read Num) rtn) Num "")))) (vl-remove nil (vl-remove "" (reverse (cons Aph (cons (read Num) rtn)))))) (mapcar (function (lambda (sym str / ent) (while (progn (setq ent (car (nentsel str))) (cond ( (eq 'ENAME (type ent)) (if (wcmatch (cdr (assoc 0 (entget ent))) "*TEXT") (if (not (set sym (car (vl-remove-if-not (function (lambda (x) (vl-position (type x) '(INT REAL)))) (ParseNumbers (cdr (assoc 1 (entget ent)))))))) (princ "\n** Text Must Contain a Number **")) (princ "\n** Object Must be Text **"))) ( (princ "\n** Nothing Selected **"))))))) '(num1 num2) '("\nSelect Text to Subtract from: " "\nSelect Text to Subtract: ")) (if (and num1 num2 (setq res (entmakex (list (cons 0 "TEXT") (cons 10 (getvar 'VIEWCTR)) (cons 40 (getvar 'TEXTSIZE)) (cons 7 (getvar 'TEXTSTYLE)) (cons 50 (/ pi 2)) (cons 1 (rtos (- num1 num2) (getvar 'LUNITS) 2))))) (setq res (entget res))) (while (and (= 5 (car (setq gr (grread 't 13 0)))) (listp (setq p (cadr gr)))) (entupd (cdr (assoc -1 (setq res (entmod (subst (cons 10 p) (assoc 10 res) res)))))))) (princ))
