srikanthkamuju Posted April 12, 2010 Posted April 12, 2010 Hi All we can create a 3D Face by using 4 points after that i want to extrude 3D Face object into solid can any one help me how to achieve it case1: if the 4 points are in non coplanar case2: if the 4 points are in coplanar thanks in advance Srikanth Quote
SEANT Posted April 13, 2010 Posted April 13, 2010 A Region entity is needed to extrude a 3DSolid; and, as we’ve already determined, a region is a “Planar” entity. Consequently, your concern about the possibility of non-planar 3dFaces is valid. Here is a portion of the requested routine (the routine gets complicated rather quickly) that will create the appropriate Region(s). It may be of some help. Sub RegionFrom3DFace() Dim varPkPt As Variant Dim ent As AcadEntity With ThisDrawing .Utility.GetEntity ent, varPkPt, "Select a 3dFace: " If Not TypeOf ent Is Acad3DFace Then Exit Sub Dim entFace As Acad3DFace Dim varRegion As Variant Dim varCoords As Variant Dim bln3Sided As Boolean Dim blnFlat As Boolean Dim i As Integer, j As Integer Dim pts(3) As Variant Dim pt(2) As Double Dim dblInitVect() As Double Dim dblNextVect() As Double Set entFace = ent varCoords = entFace.Coordinates For i = 0 To 3 For j = 0 To 2 pt(j) = varCoords(j + (i * 3)) Next pts(i) = pt Next bln3Sided = CompPTs(pts(2), pts(3), 0.000001) dblInitVect = VectorCross(VectorFrom2Pts(pts(0), pts(1)), _ VectorFrom2Pts(pts(0), pts(2))) dblNextVect = VectorCross(VectorFrom2Pts(pts(0), pts(2)), _ VectorFrom2Pts(pts(0), pts(3))) blnFlat = IsVectorZero(VectorCross(dblInitVect, dblNextVect)) If bln3side Then Dim ents(2) As AcadEntity For i = 0 To 2 Set ents(i) = .ModelSpace.AddLine(pts(i), pts((i + 1) Mod 2)) Next varRegion = .ModelSpace.AddRegion(ents) Else If blnFlat Then Dim ents3(3) As AcadEntity For i = 0 To 3 Set ents3(i) = .ModelSpace.AddLine(pts(i), pts((i + 1) Mod 4)) Next varRegion = .ModelSpace.AddRegion(ents3) Else Dim ents1(2) As AcadEntity Dim ents2(2) As AcadEntity Dim varRegs2 As Variant For i = 0 To 2 Set ents1(i) = .ModelSpace.AddLine(pts(i), pts((i + 1) Mod 3)) Next For i = 0 To 1 Set ents2(i) = .ModelSpace.AddLine(pts(i + 2), pts((i + 3) Mod 4)) Next Set ents2(2) = ents1(2) varRegion = .ModelSpace.AddRegion(ents1) varRegs2 = .ModelSpace.AddRegion(ents2) End If End If End With End Sub Function CompPTs(dblPt1 As Variant, dblPt2 As Variant, dblTol As Double) As Boolean CompPTs = False If Abs(dblPt1(0) - dblPt2(0)) < dblTol Then If Abs(dblPt1(1) - dblPt2(1)) < dblTol Then If Abs(dblPt1(2) - dblPt2(2)) < dblTol Then CompPTs = True End If End If End If End Function Function VectorFrom2Pts(dbl1stPt As Variant, dbl2ndPt As Variant) As Double() Dim dblDummy(0 To 2) As Double dblDummy(0) = dbl2ndPt(0) - dbl1stPt(0) dblDummy(1) = dbl2ndPt(1) - dbl1stPt(1) dblDummy(2) = dbl2ndPt(2) - dbl1stPt(2) VectorFrom2Pts = dblDummy End Function Public Function VectorCross(dblVect1() As Double, dblVect2() As Double) As Double() Dim dblDummy(0 To 2) As Double dblDummy(0) = dblVect1(1) * dblVect2(2) - dblVect1(2) * dblVect2(1) dblDummy(1) = dblVect1(2) * dblVect2(0) - dblVect1(0) * dblVect2(2) dblDummy(2) = dblVect1(0) * dblVect2(1) - dblVect1(1) * dblVect2(0) VectorCross = dblDummy End Function Function IsVectorZero(dblVector() As Double, Optional lngPrecision As Long = 6) As Boolean IsVectorZero = False If Round(dblVector(2), lngPrecision) <> 0# Then Exit Function If Round(dblVector(1), lngPrecision) <> 0# Then Exit Function If Round(dblVector(0), lngPrecision) <> 0# Then Exit Function IsVectorZero = True End Function Quote
