Acad to Solidworks
Zoobz
whould anyone pleaase be able to tell me if it is at all possible to convert a autocad 3d model to a solidworks 3d model?
solidworks dwg editor keeps telling me that the autocad file is corrupt even though ive drawn it several times ?
cheers guys
"SolidWorks can also import 3D DXF/DWG data as curves in the part environment that can be used to create solid models. 3D DXF files are also supported for import within SolidWorks."
Are you trying to import the drawing file of the object you have posted in another thread as Shell03.dwg?
It's all beyond me I'm afraid. I do not use Solidworks.
You can't take the 2D content and create a 3D model?
...to open it up through the DWG Editor, without success.
Why? What is your purpose in SWx?
You say it is a solid?
If so acisout in AutoCAD and then open that in SWx.
Does Autocad give you an error? What does it report on the command line?
Hit F2 and copy and paste the contents of the text window here.
I'm assuming that you checked the correct folder where you specified the file to be saved?
