koen Posted May 19, 2010 Posted May 19, 2010 I got some tools from my teacher at school . i got some tools in a map . I've installed according to instructions. these are the instruction - first go to options - tap on support file search path -then ad a new one named C:\Program Files\Autocad 2010\support\Tools. -select it an browse the map meubeltools -after that you need to enter a code in the commandmenu . I believe the code is called loadmenu . it might be that the code is wrong after that where can i find the tool . at school we have 2007 . if you click top right you see arena and in that map should it be but in 2010 there is no arena Quote
ReMark Posted May 19, 2010 Posted May 19, 2010 Are there two separate questions here? One about the "tools" and the other about something you call "arena"? Quote
koen Posted May 19, 2010 Author Posted May 19, 2010 yes but the main question is the code correct. because when i fill it in the command menu it says unkwown command. and is this correct what i do . Quote
ReMark Posted May 19, 2010 Posted May 19, 2010 I believe the command you are referring to is menuload not loadmenu. What about this "arena" you mentioned? Do you mean an aerial view? Quote
koen Posted May 19, 2010 Author Posted May 19, 2010 if you want to add the menu you can click whith your right mouse button at top right . there appears a menu where arena by state. in this menu you can add menu's Quote
koen Posted May 19, 2010 Author Posted May 19, 2010 if i enter menuload i can couldn't find the meubeltools Quote
MarcoW Posted May 19, 2010 Posted May 19, 2010 Koen can you PM me? Reason is I could explain better tou you in dutch. Koen kun je mij een PM sturen? Ik kan het je beter in nederlands uitleggen. Quote
MarcoW Posted May 19, 2010 Posted May 19, 2010 LOL Nevermind, I will do English like the rules on this wonderful forum tell us. First set up all tools in the folder you want, like in: C:\Program Files\Autocad 2010\support\ToolsIf the folder does not exist create it. Next: put all your stuf in there, no subfolders! Go to autocad and->options->first tab->supportfile search path> Her you need to add a new path, diecting to the folder you created. Now depending on what is in your toolbox, you have several options: If there are *.lsp files in there, you need to load them with appload. If there are *.mnu files you need to load it with menuload. So to go further I need to know what files you have got in your toolbox. (Dus welke bestanden zitten er allemaal in je map met tools). Ready for the next step. Quote
koen Posted May 19, 2010 Author Posted May 19, 2010 .BMP) /(.mnr)/ dwg/(.cui)/(.mnc)en jpg bestanden. het zijn vooral afbeeldingen van deuvels en lammelo's en draadnagels en nieten Quote
MarcoW Posted May 19, 2010 Posted May 19, 2010 Please keep it English like the rules ofd this forum say. Looks like you want a menu in Autocad to insert blocks, is that correct? Put the files in the folder as I said and try to load the *.cui file with CUILOAD. Does that make any sense? Quote
koen Posted May 19, 2010 Author Posted May 19, 2010 ik heb het al gevonden iI found it thanks for everything Quote
MarcoW Posted May 19, 2010 Posted May 19, 2010 We would like to know what the solution to the problem was so not only you have provided from this thread but also others. Thanks and good luck. If you ever need me, PM to go Dutch.! Quote
koen Posted May 19, 2010 Author Posted May 19, 2010 I typed in the menu to load, and i did not saw him . i vergot to select cui bestanden Quote
