At first I was able to check the length and height of my Angle Iron shape that were inserted from AutoCad blocks. But now Properties window didn’t show the steel length or depth info. What happened? I added bolted holes using cylinder command and construction lines on the angle irons. Just curious how to get objects properties info to show all information. Thanks.
