Hi all,
If one wants to change the viepoint with comands from "view" toolbar or with
_-view _top command (for example top)
every time the view is changed the model zooms out to model limits.
If one use the navcube the same happens.
I am not sure how you people are working with this method - I tried a few times and often I can't find the object I was looking at before zooming out.
However - if I use the navcube, but the object(s) is/are preselected - the view gets rotated right way, but it zooms out to the limits of the object(s) preselected.
Unfortunately, when you click the cube to change view, the command is not written in command history, so I don't know what to put in LISP to assign shortcut to that command.
Is there a way to find out what command is used when clicking on navcube to change viewpoints?
Thanks in advance
