Showing results for tags 'area command'.
  1. Dear all; The properties not showing the hatch area of specific hatchs I attach the cad file thanks Romano cad tutor.dwg
  2. Hi every body , the lisp named CAR is a lisp routine to calculate the area of any entire polygon drawn in AUTOCAD. How to use : 1- Run the Autocad. 2-Load application named "car" or directly drag it into the autocad. 3- the command for the lisp is " car " enter 4- select the polygon u want to know its area. CAR.LSP
  3. Want to calculate area by selecting the points in sequence for a closed poly line. I had done it before with no problem. Now it doesn't show any result. After selecting last point (one before the first point) and hitting ENTER to make a closed area, it just returns to command prompt with nothing happening. Am I doing something wrong? Windiws XP, AutoCAD 2007
