Showing results for tags 'assign material'.
  1. Hello, Im using AutoCAD, AutoCAD Mechanical 2009 and Mechanical Desktop 2009 I have parts that have a material assigned to them through the 'MASSPROPS' dialog box. When assigning the material to a part, material properties associated with that part are assigned as well. Is there a way to either remove the material assignment or create a "dummy" material with material property values set to 0 and assign this new material to the part using AutoLISP? If not AutoLISP, is it possible using any other code type?
