I am using attributed text wire tags. I was wondering if there is a quick way to add a D to the front of my wire tag? The fastest way I have found so far is using the properties box EX. tag S,V. When I select multiple wire tags S,V on my wire run and the S,V shows up in the properties box then I can add my D. If I have a SV 2S,V 2S,2V selected then the properties box says varies. Is there a lisp or a solution to this problem?
