Showing results for tags 'auto drop'.
  1. andar424
    auto drop fasteners
    If I'm using the auto drop feature for placing bolts into assemblies, what is a fast way to change those bolts sizes? I see the change size in the small menu that comes up while you are using it, but once you change the size, that menu goes away. Also, I won't change the size, I use the auto drop, it gets all my bolts in the spots, but then it is the wrong size. How can I quickly change all the bolts? Is there a way to change multiple bolts at the same time? Thanks!
