Hi Guys, got a question regarding the application of multiple attributes in a block.
In space planning I make a lot of blocks with a text code in them that I apply a rotation to so it can be rotated on plan to always be the right way up.
i.e. a simple hatched rectangle representing a desk with the word "desk" in it.
I would populate a plan but some will be vertical, some diagonal and some horizontal so the rotation allows me to set all the text the way I want it.
Now I have also started to apply an array on a linear attribute so I can run a string of desks.
Unfortunately, applying this to a block as detailed above allows me to run a string of desks that all have the text in but they all rotate around the initial blocks text rotation point.
Can the two features be applied so once the array is run, the text in each block can be rotated individually?
Sorry if not clear lol!
