Showing results for tags 'block spacing'.
  1. Hello Everyone, I am looking for a LISP routine which user defines an area (rectangle) and a blocks and 2 numbers x & y (array dimension) and the the routine place the amount of blocks inside the rectangle. NB: the distance of block-edge of rectangle shall be distance of block-block divided by 2. I need to use this routine to place for me the lighting fixtures. lights must be away from walls half distance of light to light. Thank you experts. Chemra
