Showing results for tags 'block text editing'.
  1. Hi lisp legends. When inserting a block with text, you need to go through "block editor" to edit it and if it has attributes, you can use attedit. Is there a way to simplify editing the text in an inserted block? like editing MTEXT or TEXT that you only need to double click it? Thanks a lot legends.
