Showing results for tags 'cad lt'.
  1. I'm trying to write either a script or a macro to make it easier to do an array that we will need to replicate on a regular basis. Basically, I want a path array to offset mtext every 20m along a centreline. If I do this in the command line, it's fine: ARRAY select object PA [path] select path curve M [method] M [measure] I [item] 20 [distance apart] F [fill length of path] A [align to path] Y [confirm] X [exit] If I do this in a script or macro, I encounter a difficulty in that the type of array is limited to polar or rectangular. It doesn't even register that path is an option. If I try a similar thing using ARRAYPATH, the options that come up from the macro/script are totally different to the command line options. Am I missing something, or is CAD just unhelpful on this? Running LT, so can't do LISPs
