Showing results for tags 'centreline not smooth'.
  1. Hi.. I'm relatively new and self taught on inventor so please excuse any blinding error I've made.. I'm having some trouble lofting a part along a 3d sketch path. When I select the two end sketches and choose the centreline path, Inventor keeps kicking back an error that the centreline is not smooth. I'm not sure how to resolve as the centreline is simply two lines connected together. Interestingly if I use the sweep command and use the same centreline Inventor has no issue. I've attached the part below. I'm trying to create a hook shape.. If someone knows what I might be doing wrong so I can avoid in the future it would help loads.. thanks hook.ipt
