Showing results for tags 'command saveas suffix'.
  1. Hi, I have about 1500 drawing in witch i woul like to run a command based on the name of the file ex: () So in Every files startinf with 3-ML2030 I would run the "2030PSQ" command and then save as adding PSQ as suffix for the file name. And i Would do the same thing again but this time with "2030OVA" command adding OVA suffix. I would need to be able to recreate this path with the 2030, 2036, 2042, 2430, 2436, 2442 drawing sorth it would be finding wath command to run depend of the name of the file. Am i clear Thanks!!!
