Hello,
I'm not used with forums, please forgive if I forget some respectfull form,... english is not my mothertongue.
Well, the problem is with redefining command. After months or years of trials it seems to me to be the best way for what I want to do is to redefine command, allow the "innocents" to be processed and prohibe the "specifics" to be so, a further code will apply to them.
Seems easy, but one BIG problem:
in the define routine, the ssget command does not give the expected result. It does select objects but just remove every first entity of a serie of blocks.
Please look at the code, in lst1 are the names of blocks "prohibited" to be processed. I think names of blocks are not important.
It's the first time the ssget give me this result. Is it known problem ?
Here the code for mirror but the problem is the same with move, copy, erase.
Thanks for helping.
redef.lsp
